2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Staggered Setup for XDrive?
      09-17-2016, 01:24 AM   #1
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
Hey guys,
So the next thing I want to get is rims for my car. I really want to get rid of that wheel gap. My question is that can I run a staggered setup with Xdrive?
Also, any recommendations on rims for my car?
Thank you!
      09-17-2016, 05:09 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No issues with staggered setups on xDrive cars, just need to match front and rear tire diameters. Two possible tires setups, either 245/285 or 255/295.
Exampel of staggered wheel and tire combos for F10 xDrive:
F: 8.5x20" ET25, 245/35-20
R: 10x20" ET40, 285/30-20
F: 9x20" ET30, 255/35-20
R: 10.5x20" ET45, 295/30-20
The wheel offsets can vary a few mm without issues. Wheel diameters can be 19, 20 or 21", but the tire profile needs to be matched for chosen wheel size.
      09-17-2016, 12:37 PM   #3
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Lower the car to get rid of the wheel gap.
      09-17-2016, 07:06 PM   #4
5eries619
Drives: 528i x drive
no issues with staggered setup on my x drives. running on Vorsteiners 20s 20 x 10.5 rear and 20 x 9s front.
      09-26-2016, 10:43 PM   #5
E30toF30
Drives: 2016 528i Executive Edition
Just wanted to add, if you go bigger wheel while maintaining the proper wheel/tire specs, going up a wheel size will actually appear to increase the wheel gap. It's like an optical mind fu#&.
The only way to get rid of wheel gap is to lower your car lol.
      09-29-2016, 10:30 PM   #6
TwinSnailz
TwinSnailz's Avatar
75
Drives: 2011 X5//M
Sorry to hijack but this might be useful to op.
Do any of you with staggered xi have weird noises on your drivetrain? Like when you very lightly step on the gas during cruising?
      10-04-2016, 06:03 AM   #7
Verdi
Sweden
250
Drives: F87 M2 -17, i3 REX -17
On my M550d xDrive the wheels that came with the car were:
Fronts: 245/35-20
Rears: 275/30-20
The rears are actually slightly smaller by some mm.
      10-18-2016, 12:28 PM   #8
Jobbu
Drives: F10
Sorry for posting to this thread, but cant make a new one.
So I drive an F10 530d XDrive and it has OEM style 351
wheels, which are staggered.
Theyre 8.5 front and 9 rear.
At the moment Im using tires 245/40/19 and 275/35/19, but winter is coming and I want to use spiked tires, sadly manufacturers doesent produce spiked tires in this size or they are really hard to get.
Since I have xDrive I cant just put any other size tires on them because of the circumference difference which will start damaging the transmission.
I used a tire calc and got a 0% difference with tires 225/45 and 255/40, the difference of radius is 0.2 inch.
On paper it should work, but Im not an expert and still hesitating, dont want to ruin the transmission.
What do You guys think? Am I okay with this setup? I dont mind the stretched tires, main thing is that I can drive without damaging anything.
      10-18-2016, 01:16 PM   #9
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Those sizes will be fine with xDrive.
F30 M Sport with xDrive has 225/45 front and 255/40 rear from factory, but with 18" wheels.
Since you don't mind the stretched tires, I don't see any other issues either.
      10-18-2016, 02:46 PM   #10
remmib
remmib's Avatar
Norway
1568
I'd just go 245/40/19 all around.
I've done that myself, studless tires though and no xDrive.
      12-08-2016, 03:14 AM   #11
Thieutje
24FITcoach
Thieutje's Avatar
Belgium
32
Drives: BMW F11 M550xd
This seems to work fine a more agressive offsets
http://f10.5post.com/forums/showpost...75&postcount=5
      09-12-2019, 09:54 PM   #12
OldCrow7xx
Drives: 2016 M235i Xdrive 8A
Hey so like the only thing that matters is the rolling diameter? All the other variables can be different? Asking for an m235xi owner.
Thanks
SOLD 23K Black 2013 F30 335XI 8A Msport | BMS Intake | BMS Front Mount | VRSF Charge Pipe | BM3 Tune
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete
      09-16-2019, 09:20 PM   #13
palle2612
Denmark
20
Drives: Bmw F11 535d Xdrive
Hi. Newbe on the forum.
Just wanted to ask If one was going to use a 245/35-20 for front, how about load index... a 245 tyre dosen’t have a load index high enough for my 535d xdrive, ( which is supposed to have 96 If I recall correctly )🤷🏼*♂️
What’s your take on this
      09-18-2019, 02:09 PM   #14
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Correct.
      09-18-2019, 02:10 PM   #15
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
245/35-20 is the OEM 20" tire size for F10, i.e. no issues.
      09-20-2019, 12:57 PM   #16
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Correct.
Does it matter if you change the overall diameter to be different from the OEM? As long as the front and rear diameters are still the same, the only thing that would be affected is the speedometer right?
      09-20-2019, 02:13 PM   #17
wcr3d
Drives: 2013 535i XDrive M Sport
I imagine your wheel speed sensors will complain.
Normally people that move from 18, 19 or 20's keep the same diameter usually within 1%.
      09-20-2019, 03:18 PM   #18
Unspec
Unspec's Avatar
1300
Darn, was hoping I could run a bit thicker sidewalls when I go to 19's.
      09-20-2019, 03:28 PM   #19
TEF
Drives: 16 X3 28d/18 540d xdrive
2018 540d xdrive  [0.00]
2016 X3 28d  [0.00]
Changing overall diameter of all wheels should cause no problem other than a slight speedo error. I did this on my X3 when changing all four tires from 245/50-18 to 235/55-18. The diameter of the latter is slightly greater, but the vehicle was not negatively affected by the small difference.
      09-20-2019, 07:55 PM   #20
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
I ran 245/50/18 winter tires on my F10 for four seasons with no issues.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
