12-10-2016, 07:07 PM | #1 |
Rep 106
Stripped bolt
So I was swapping out my tires for the winter, and I get to the last tire. One of the bolts wouldn't budge, so I extended the handle to get more leverage and there goes head of the bolt. Stripped. I'm figuring whoever tightened the bolts last over torqued it. Any suggestions?
12-11-2016, 10:32 AM | #2 |
Rep 14,522
May try using an extractor to get it out. Had to use that when I broke my caliper bolt on my Titan
12-11-2016, 04:23 PM | #4 |
Rep 14,522
he said the head bolt broke off so i'm assuming all that's left is the broken stud which if he uses an extractor it's a possibility he can take it out (cross fingers)
12-11-2016, 04:27 PM | #5 | |
Rep 4,553
There goes head of bolt. Stripped. I'm not sure if he meant the head broke off or it just spins. Sounds like he may need to soak that in some lubricant before trying to extract. Could be a tough one.
2023 840GC | 2021 740i | 2019 X3
12-11-2016, 09:23 PM | #7 |
Field Marshal 🔱
144
Rep 294
Drives: 2019 M5 Competition (F90)
Depending on how daring you are, you can drill into it and use and extractor as others have said. Maybe also cut a slot into it?
2019 F90 M5 Competition - Black Sapphire Metallic
2015 F10 535i xDrive M-Sport - Jet Black (retired) 2008 E60 528i - Space Grey (retired) 2002 E46 325i - Space Grey (retired) 1999 E46 328i - Orient Blue (retired) |
12-12-2016, 06:46 PM | #8 |
Rep 106
I wonder if something like this would work
https://www.amazon.com/Craftsman-Bol...tsman+bolt+out |
12-12-2016, 08:26 PM | #9 |
Rep 14,522
doesn't hurt to give it a try!
12-13-2016, 05:41 AM | #10 |
Rep 106
I'll let you known how it goes. Wish it was a bit warmer though.
What psi are people running on their winter tires? I've got 255/40/19 but the manual doesn't specify for this size tire. |
12-13-2016, 08:42 AM | #11 |
Rep 2,196
Just bring it to a good tire shop. They deal with these issues all the time. Just have a replacement bolt handy. I bet they get it done within 10 mins for you.
Bake
12-19-2016, 07:26 PM | #13 |
Rep 14,522
what happened?
12-19-2016, 07:50 PM | #14 |
Rep 106
The bolt/nut remover just cracked. I just started cranking on it and it just cracked in half. I probably should've heated it up a bit, but was afraid of damaging the rim with the heat gun.
12-20-2016, 07:31 PM | #15 |
Rep 106
That sucker was on there, took the guy 15 mins to get it off. He was about to give up until he tried 1 last time. Chipped the rim a bit, guess I'll be swapping those for the winter set next year, lol
12-21-2016, 03:20 AM | #16 |
Rep 14,522
well good to hear you got it off!
12-27-2016, 01:40 AM | #17 |
Rep 1,085
Drives: 2013 BMW F10 550 Xdrive Msport
In the future, remember that the tightening torque on the wheel nuts should be 140 NM, around 100 ft lbs of torque. EVERY time you have the tires worked on, go home, bring out your torque wrench and SET your torque properly. Even BMW dealership never does this right, or rarely. Having over tightened lug nuts can cause the problem you experienced, warped rotors and not having the ability to change out a flat tire if you go away from Run Flats. I would also recommend that if you live in an area that has snow and salts the roads, that you ensure you user Neverseize on the area where the Hub makes contact with the rim (NOTHING ON THE LUG NUTS). What I have seen is that the hub and rim contact area will rust and make it damn hard to remove the rim after all the lug nuts are removed. I use a fine sandpaper to take off the rust that is there and use a LIGHT amount of neverseize on the hub/rim contact area and you will not experience any rust lock from it.
12-29-2016, 07:53 AM | #18 |
Rep 106
Thanks for the advice! When I take the snow shoes off I plan on putting spacers, I'll get rid of the rust and put some neverseize on. Noticed the rust and the extra knock on the tire to get to pop off.
01-02-2017, 01:32 AM | #19 |
Rep 1,085
Yes and it only gets worse with time. I have helped others where it took a good half hour of banging, kicking and fighting before getting the tire off. One would think the car companies would use a teflon coating or a never seize compound themselves on this, But then again, BMW won't even allow us to have derive manuals. Lol
