2010 2011 BMW 5 Series Forum F10 Callipers Repainted & Added M Decal |
06-20-2015, 05:00 PM | #1 |
Rep 2,271
Yesterday had a few hours spare so decided to repaint my callipers. Previously done them around 2 years ago but now they needed a fresh coat.
As last time I used VHT Bright Blue (comes out dark though) and VHT Clear Gloss as a top coat. This time round I added an M Decal on the fronts too. Wasn't sure about doing this but I think it looks good. I did 2 coats of the blue 20/30 mins apart and 2 coats of clear gloss. I used a portable site light as heat to cure the paint after each coat. Gave me a chance to also clean the wheels from the back while I had them off the car. Took around 4/5 hours in total. The prep work was the biggest task masking and covering the bits off that didn't want painting or over spray. Few pics below. Paint: Decals: Curing: Finished look: Finished look: Masking removed: (Bricks were there as a safety precaution. I've had a jack fail on me before and bricks saved the car) Without decal: Decal added: Finished look: All done:
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
06-21-2015, 03:51 AM | #4 | |
Rep 2,271
__ Stickers are from well known auction site. Link below: http://www.ebay.co.uk/itm/2013584699...%3AMEBIDX%3AIT What colour did you do your callipers?
IG: project540ix
06-21-2015, 08:24 AM | #5 |
Rep 10
Thanks for the link
Done mine 18months ago, using Halfords own brand calliper paint which I chose to match the BMW logo wheel centres(hand painted) looks okay, but definitely need redone and after seeing your photos, going to do same colour as you have,looks better and very much like factory fitted colours on new models. |
06-21-2015, 08:45 AM | #6 | |
Rep 2,271
That colour looks good too. I like how it matches the badge colour . I guess with hand painting you have more control of where the paint goes. With spray paint I found you have to spend alot of time masking bits off but worth it in the end. I've put the links to the spray paint below... Blue: http://www.ebay.co.uk/itm/3803765755...%3AMEBIDX%3AIT Clear Gloss: http://www.ebay.co.uk/itm/3809136129...%3AMEBIDX%3AIT
IG: project540ix
06-21-2015, 08:55 AM | #7 |
Rep 10
Again, thanks for links,
Yep, spraying means a lot more prep,but after seeing your pics definitely a better result and worth the extra time.. |
06-21-2015, 01:51 PM | #8 |
Rep 215
Looking good :-)
Rich
Current : 2022 G05 X45e Previous : G30 520D SE / F10 520D SE / F31 320 M-Sport Touring / E92 320D SE Coupe |
06-21-2015, 05:00 PM | #9 |
Rep 10
Junebug 85.....
Have now ordered via links you put up, one of each.....but now thinking if one aerosol of blue enough for two coats of the four calipers or would more be required ?? Also,did you put the decals on after both the clear coats .....or after the first coat was dry then the second coat over the decals to seal them in.....?? |
06-22-2015, 02:33 AM | #10 |
Rep 2,271
IG: project540ix
06-22-2015, 02:43 AM | #11 | |
Rep 2,271
I put one clear coat on, then waited for it to dry completely, apply the decal and then another clear coat to seal it. Post some pics up once you've done it. Will be good to see .
IG: project540ix
06-22-2015, 03:34 AM | #12 |
Rep 10
Thanks again for that,
Was hoping one would do it....as order already in for just the one ! Will post some before and after pics, once I get round to it ! Could be a while though,off to find the sun on hols soon, as it doesn't show face up here much and will need a dry day to get going with the job in hand. |
06-22-2015, 03:52 AM | #13 |
Rep 14
Drives: F11 M-Sport
Been looking at getting mine done, but been unsure on which colour, yours look great.
06-22-2015, 07:20 AM | #14 |
Rep 8,081
Won't the sliding parts, pins and pad slides get gunked up with paint?
The pukka painted M-Sport callipers are proper 4-pot opposed pistons - these are single piston sliding callipers. I would have thought spraying several coats of paint and lacquer will prevent them sliding correctly.
Ian
06-22-2015, 09:34 AM | #15 | |
Rep 2,271
Brake pads and discs have been changed on front and back after being sprayed first time and the dealer didn't have any issues with the changeover.
IG: project540ix
06-22-2015, 09:35 AM | #16 |
Rep 2,271
Thanks. What colour is your car?
IG: project540ix
07-10-2015, 04:01 PM | #17 |
Rep 10
Got round to re-painting my calipers from old blue to the blue that you shared with the links,really pleased with them......thanks to you
07-11-2015, 10:42 AM | #18 |
Rep 79
A couple of really good results there lads, well done.
I done the brakes on my Z3M a couple of months ago, however in Silver. The car was off the road and needing pads anyway so pull the brakes apart completely and cleaned/painted them up. I will attach the results just for the craic. If I was to do the 5 series ones, I think I'd remove the pads and paint the rattle clips separately. And a wee chance to photowhore... lol
07-12-2015, 11:11 PM | #19 | |
Rep 2,271
How many coats of blue and lacquer did you do?
IG: project540ix
07-12-2015, 11:16 PM | #20 |
Rep 2,271
Yeh I guess the proper way to do it is remove the pads and clip. Loving the CSL!
IG: project540ix
07-13-2015, 03:08 AM | #21 |
Rep 79
Looking back, since I had them off the car and given the state they were in, I should have really had them sandblasted first. Had a couple of parts on that car blasted and primed, boy made a cracking job on them too, he was local and handy paid.
07-13-2015, 07:30 AM | #22 |
Rep 10
