2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions How To: F10 Rear Brake Disc and Pad Replacement
      08-14-2021, 09:35 AM   #45
jointone
jointone's Avatar
Drives: BMW F10
Thanks. Great guide.
      08-29-2021, 08:05 PM   #46
dnorfolk
Drives: BMW 528i
I changed my rear brake pads and had no issues that I know of. Reset the brake wear sensor on the dash, but the parking brake will not work anymore. Nothing happens at all when I try to engage it.
What did I do wrong?
      08-29-2021, 09:10 PM   #47
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
How did you push the piston in? If you did it manual make sure the electric ebrake plug is plugged in all the way. I did mine using ista and it worked right after I was done changing the rear brakes
      08-29-2021, 09:18 PM   #48
dnorfolk
Drives: BMW 528i
I did it manually. I left out above, but the auto hold is also not working now.
I did double check that the plug was in all the way.
      08-30-2021, 09:15 AM   #49
ramman434
Drives: F30 335i
dnorfolk you're brake actuator's may have gone bad. I had one take a shit a few months ago. Do you hear them trying to engage at all? I also was getting a malfunction warning on the dash. I made a thread about it somewhere on here...
I completely replaced both units when I did my brakes a couple of months ago. Bought them for $47/ea off of Amazon. Haven't had an issue since:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
'07 Montego Blue/Saddle Brown E92 335i - 6spd. - SOLD
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
      12-21-2022, 06:48 PM   #50
adumesny
Drives: 2014 528i
Originally Posted by dbmw335 View Post
So I just changed the rear pads on my 2014 535 (F10) ....
When I tried to reset the service interval... "reset unsuccessful".
Searching on the web I found a procedure that allowed me to successfully reset as follows:
1) Disconnect the brake sensor harness inside the service door on the right rear wheel well (like you would if you replace the sensor)
2) Use a thin wire to jump the connector on the car (e.g. make it a closed circuit) where you just disconnected the harness.
3) Reset the service indicator via the odometer button on the dash.
It will now reset properly!
4) Remove the jumper wire and plug the sensor back in.
So I just changed front+back rotors+pads on my 2014 528i as well using Foxwell 510E BMW to retract the rear e-brakes (much easier than taking it appart and manually backing it up with hex bit) but I also cannot reset the service interval (also done before sensor was worn off).
I tried the steps above, using a wire to jump the plug (similar to last step shown in https://www.youcanic.com/bmw-brake-s...-unsuccessful/) but still "reset unsuccessful" - not sure how wire is any different from a good sensor with a closed circuit anyway... maybe disconnect for a while is the trick ?
I did read some errors codes related to brakes (I locked the car overnight wile still in brake retract mode ?) but clear them with the Foxwell 510E and will have to try resetting it again... car drives fine, but I have a <500mi reminder with 4 new brakes
UPDATE: did it again, this time with a thinner wire from a resistor (that I twisted to short circuit it) and was able to reset both sides after disconnecting the sensor for a while with ignition on. the Foxwell also informed that you cannot reset unless it detects a change (hence the disconnect and reconnect) but also that you need parking sensor off and not have brake pedal pressed (so block the wheel to prevent rolling). Not sure if that later part matters, but in case it helps another user...
      01-20-2023, 12:53 PM   #51
adumesny
Drives: 2014 528i
Weird - 2 weeks later and car now says both brakes are -200+ mi past due and to 'drive carefully'
I reset them again (back to 60k) using steps above, but as soon as I drove it jumped down to 600mi! I'm guessing my sensor wire must have got damage during the removal as I wasn't able to reset the service internal with them but had to use a solid wire instead. So, I reset (using a wire) and left it in there - sensor were not that useful to start with as my front brake worn down to the metal on one side and the sensor (on the other pad) had plenty left - so better to check brake regularly than depend on tech!
Weird thing is now both brakes (even though I only disconneted then hard wired the front) reset to 3.1 and 3.7k !
this all BMW pad reset is a PAIN in the butt... and apprently rather flacky. wish the Foxwell 510E had a force reset intead of having the take the wheels off each time to access and disconnect the sensors. I don't even have 60k+ interval now (first change was 92k for me). Agrrr...
      04-29-2023, 10:45 AM   #52
EVO_F10
Drives: BMW 535i
Nice, thanks!
