2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions HID Fog lights
      04-22-2017, 01:24 PM   #45
Graffix
Graffix's Avatar
23
Drives: 2013 550 xi M sport
HID fog lights
      04-24-2017, 11:06 AM   #46
ALPWhite
Drives: 2013 Alpine White 535iX MSport
Originally Posted by Graffix View Post
HID fog lights
I still have the Morimoto kit as per my last reply in this post from late last year and all is still working fine. Is there something specific you had a question about?
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
      04-24-2017, 10:20 PM   #47
Graffix
Graffix's Avatar
23
That pretty much answers my question, thanks.
Has anyone seen, heard or installed the iJDMtoy.com LED fogs?
      05-03-2017, 11:45 PM   #48
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by bobblehead View Post
is this the one i can use for my non m foglights?
https://www.theretrofitsource.com/al...ect_restrict=1
edit: think i found my anser here. looks like i need the H8 35w
If you have Msport, then it's H11. For regular - non Msport, it's H8. 35watt is preferred
the error eliminator is the canbus harness (you will need this 'optional' harness when ordering)
Just a word of caution, bmw electronics is very sensitive to voltage irregularities and when it does detect such occurrence, there is a chance your ecu will shut down the lighting module and will light up the error message of "Light control module malfunction". Such that it is not a warranted item and this LCM module alone costs around $1,000.
speaking of personal experience in the past and that's why I don't play around with bmw's electronics gadgets anymore. I am sure thousands of people have done it and hopefully, you are one of the lucky ones.
If you are interested, here are some pics that I had switched over to halogen yellow fog lights.
http://f10.5post.com/forums/showthre...ght=fog+lights
      05-04-2017, 03:44 AM   #49
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
The reviews on those are shitty, and bad customer service, retrofit source is the only place I would get hid's from in that price range, they only get more expensive from there.
      05-04-2017, 07:34 PM   #50
Graffix
Graffix's Avatar
23
Thanks for the reply.
Anyone know if its H11A or H11B? I know it's H11, but the a or b came out of left field.
      05-05-2017, 03:50 AM   #51
ALPWhite
From my order confirmation:
Order Items:
Item Qty Subtotal
H11: Morimoto Elite HID System 1 $150.00
HID Ballasts
2 x 35W: Morimoto XB35 Computer $70.00
Ballast Igniters
2 x Morimoto XB Igniter (AMP) $30.00
Compatible H11 HID Bulbs
2 x H11A: XB 4500K $25.00
Harness (See Compatibility Info Below)
2 x Canbus: H11/H9/H8/880 $25.00
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
Graffix22.50
      05-05-2017, 07:16 AM   #52
Graffix
Graffix's Avatar
23
Thanks
ALPWhite137.50
jjwwuu2.00
      10-01-2019, 11:31 PM   #53
Sylverlee
Drives: White 535i M-Sport, 911 GTS
sorry to bump older thread - but where do you guys mount your ballasts w/ msport? btw you go through wheel well or the front grill?
      01-19-2020, 07:48 PM   #54
ALPWhite
Sorry for the late reply , I tucked mine in the little cavity where the fog lights are. Right behind the plastic mesh.
Current: 2013 F10
Previous: 2007 E90
Previous: 1994 E34
      01-20-2020, 09:38 PM   #55
Sylverlee
No worries. Was an easy install, love it.
      03-01-2020, 06:50 AM   #56
marmit2017
marmit2017's Avatar
Drives: 11 535i 13 328i xDrive
So obviously these are going to be somewhat blinding to oncoming traffic? But are they terribly bad? That's my only worry, I don't want to be that douche that's blinding oncoming traffic
      03-01-2020, 07:24 PM   #57
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Post number 3, picture number 1:
You can see just how blinding these are. Notice how the fog lights look a bit oblong and shine slightly above the bumper? That's because the light is shining directly into the camera lens so brightly that it's creating a reflection on the lens.
I'd stay away and just swap out the entire unit for the LED fogs, you can pick them up pretty cheap used from various sources.
2015 BMW 535xi
ISTA VM Setup/Tutorial
