2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2013 535i Sport mode?
      12-27-2012, 01:51 AM   #1
E92///M3
Drives: 2012 E92 M3 Coupe
When I test drove a 550i, the salesman switched the drive to sport mode on the toggle on the left of the gear selector and the car naturally revved higher and had more acceleration. What is the name of this option? Adaptive Drive?
      12-27-2012, 02:04 AM   #2
L7AS
Drives: '12 F10 535i
No, It's called the sport mode. Adaptive drive is different. And I believe with the EDC you should be able to adjust the sport mode, choosing to use only the drivetrain or chassis or both. Drivetrain is the one that gives more acceleration.
picked this up from BMW's website
"Adaptive Drive counteracts the forces that cause body roll. Your BMW handles with outstanding sporting agility, while also ensuring a very comfortable journey for you and your passengers. Body roll is practically eliminated, and winding roads can be enjoyed with a maximum of stability and safety."
hope this helps =D
      12-27-2012, 02:06 AM   #3
E92///M3
hope this helps =D
So Adaptive Drive is just the Active Roll Bars? I mean that feature where it toggles between those settings is it standard or is it an option?
      12-27-2012, 02:14 AM   #4
L7AS
I think with the EDC you get more option to choose from. I have the EDC option and it gives me "Sport+, Sport, Comfort, Comfort+, Eco Pro mode". But I'm not too sure about this.
      12-27-2012, 03:38 AM   #5
HighlandPete
Drives: BMW F11 535i Touring
Adaptive Drive is both the variable damping and the active roll bars.
As said, can be configured in iDrive as chassis, drivetrain, or both, changing 'reaction' levels with the modes toggle. Modes are still there without the Adaptive Drive option, but obviously with limited functions.
HighlandPete
      12-27-2012, 08:19 AM   #6
Terpinator
Terpinator's Avatar
Netherlands
10
Drives: 550i xDrive M Sport
The button (Driving Dymanics Control) that the salesman activated is standard on the 5 Series. It allows you to toggle between COMFORT, NORMAL, SPORT and SPORT +. It controls the response of the engine and transmission.
If you want the the suspension to also be tied into the system, you need to order Dynamic Damping Control. This will firm up the suspension as you move from Comfort up to Sport.
Adaptive drive combines Active Roll Stabilization and Dynamic Damping Control. This system activly counteracts the body role of the car when going through turns, keeping the car flat. A friend of mine just got a 550 with Adaptive Drive and says the Active Roll feature is amazing.
I ordered my 550 with Dynamic Damping Control, but opted against the Adaptive Drive, soley to save money.
      12-27-2012, 10:50 AM   #7
HighlandPete
Same here, my first drive with Adaptive Drive convinced me the ARS part is the key to comfort and decent handling, even in the softer settings.
I find my F11 535i wagon works well on a wide range of road surfaces in normal mode, with very flat cornering. The fact the ARBs virtually decouple on the straight, enhances ride comfort, in any mode. ARS is a superb option, one of the best ever in a 5-series car, in my experience.
HighlandPete
      12-31-2012, 12:36 PM   #8
Rapp
Drives: M3 2016 black/kidneys
Does anyone know where I can find the engine type on my 550i?
I just got my 550i M Spots from the plant. I was hoping it would come with the new upgraded engine N63tu but I can't find it stated anywhere? I feel a bit cheated right now.
      12-31-2012, 07:51 PM   #9
E92///M3
a call to your dealer should give you that info. no?
      01-01-2013, 01:02 PM   #10
bubbahead
Drives: 2022 G05 40i Msport
There are many threads on this..it was for the 5GT. It doesn't state on any BMW literature or bmw website that the 2013 550's have the new engine.....most likely for the LCI
2018 540ix msport
2015 X5 msport
2013 750ix msport
2011 550ix msport
2009 e92 335i msport
