05-23-2013, 07:10 AM | #1 |
Rep 1,684
Start stop paradox
So, if I drive my car with ASS disabled, will my starter last forever since its beefed up? How about the engine? Will it last forever too?
05-23-2013, 08:02 AM | #2 |
Rep 156
Possible that the starter will ... even on a short drive (say less than 10 miles in suburbia) my engine goes through the stop/start/stop cycle about 30 times. The most annoying is when I approach a red traffic light and am stopped for about 10-15 seconds and just as it's ready to turn green - the engine stops!!
I just turned 3,000 miles so next trip to the dealer will be to reset it to "off unless selected on". Until then I usually shift to "S" to defeat the stop-start cycle.
My opinions are free - you'll get exactly what you pay for!
Current: 2023 X5 45e MSport 2013 X1 3.5 MSport 1998 Z3 2.8 |
05-23-2013, 09:03 AM | #3 |
Rep 2,323
05-23-2013, 08:18 PM | #4 | |
Rep 1,684
There is only one way to know. And neither you nor I will be on this planet long enough to answer your question properly. But, the paradox here is that by NOT using a system (ASS) designed to save the environment, you may be really saving the environment far more by having a working engine that has been over-engineered to withstand countless brutal stop start cycles and thus this engine will stay running in a car decades longer instead of suffering a pre-mature death decaying in a landfill. |
05-23-2013, 10:09 PM | #5 |
Rep 236
Do modern BMWs really still use an electric starter for ASS? I thought all cars these days supply fuel to the cylinders when ASS kicks in and the ignition system fires the cylinders that are in compression to restart the motor. In other words the electric starter is only used when the car is first started or if it sat for a long time in traffic with ASS. The fuel in the cylinders should be good for several minutes waiting for a spark.
05-24-2013, 12:49 AM | #6 | |
Rep 538
05-24-2013, 07:51 AM | #7 | |
Rep 2,323
05-24-2013, 07:55 AM | #8 | |
Rep 2,323
Many owners do not like the ASS system, but there is really no need to justify why you dont like it. The system is not perfect, it has its glitches, thats why I dont like it. The design intention is good, but the technology is not ready yet. Like many innovation, it will get better. |
06-21-2013, 04:59 PM | #10 | |
Rep 1,684
Well, the general consensus for European countries is that this update will no longer be applied by the Centre since the patch adversely alters the published km/L statistics. For the USA, some folks have reported that this patch is no longer free, but can be applied if you are willing to pay hourly rates. My thought: Just get used to pressing the ASS defeat button the moment after you press the start button. Sooner or later, you will condition yourself to keeping the ASS disabled. Also, anytime you realise (after the engine shuts off) that ASS is turned on, always wait for your car to restart on its own (using the normal ASS restart cycle). Why? Because, even though you don't subscribe to this green nonsense, you may as well make the most of it and save the petrol anytime you become aware that ASS is actually enabled after the fact. Also, make sure you set your commute to and from work as a "trip." Then select your trip when you drive off to work in the morning. Why? Assuming your commute is longer than 20 minutes, when you get back in your car and press the Start button in the evening, your car will immediately prompt you to see if you want to be navigated to home. Click "yes" right away. Then, as you prepare to get yourself ready for departure, your car will silently be evaluating traffic conditions to get you home on the best route. |
06-22-2013, 03:47 AM | #11 |
Rep 5,095
or you can go the coding route. I recently set my to be last setting. So if I leave it off when I shut the car down, that's the state it is in when you start again.
if you google coding, you'll find plenty of information on that Easiest though as mentioned previously is just to get used to switching off when you start the car . |
06-23-2013, 06:24 PM | #13 | |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
However, what I wonder is; how does that work in the diesel engines? Surely that must be purely starter motor reliant?
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
