2010 2011 BMW 5 Series Forum F10 Headlamp question (xenon) |
02-22-2015, 12:17 PM | #1 |
Rep 634
I have had several BMWs (euro), and all my cars have always had the low beams in the outer filament, and high beams in the inner filament.
My old e46 had bi-xenon with low and hi-beams In the outer filament, and a normal incandescent hi-beam in the inner filament. Was sitting infront of a window with my -12 F11 today waiting for some people, I started to play with my light switch, noticed how the brightness of my halos changed from DRL and parking lights. When I put on my hi-beams I was surprised that nothing happened to the inner filament and it appears not to be in use at all. It looks like I have bi-xenon in the outer filament, and the inner one is just a "dummy" lamp with a halo around it. Is this really the case? Did BMW scrap the old twin headlamp function on the F10/11 and just kept the visual appearance of 4 headlamps? |
02-22-2015, 01:18 PM | #2 |
Rep 40,753
Drives: 2018 Alpina B6 650ix GC
That is correct. The outside bulbs are bi-xenon for low-beam and high-beam. The inside bulbs are your cornering lights and they come on in reverse as well.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
02-22-2015, 06:41 PM | #3 |
Rep 27
Drives: MY13 F10 528i M Sport
Have the same sets of Xenons (non-adaptive) tried various methods to get them on, but failed. Even by turning the steering.
'13 F10 BMW 528i Sport: Space Grey / Leather Dakota Black - Head Up Display | Hi-fi Professional with DSP | Double Spoke 350M Alloys with Summer Setup | Navigation System Professional | Bi-Xenons | Sports Seats | Hot Climate Version | PDC | Rear View Camera | Aluminium Hexagon Interior Trim | Sport Automatic Transmission |
02-22-2015, 11:59 PM | #4 |
Rep 18,713
@shawnsheridan, is it possible to code the cornering light to light up the fog light instead of the inner lights?
Like the F15 X5. Cuz my '14 F10 got the LED foglight.
02-23-2015, 04:22 AM | #5 |
Rep 29,202
Why, the cornering light is much better than the fog light to light up the road.
02-23-2015, 05:24 AM | #6 |
Rep 40,753
The Cornering Light function is part of the Adaptive Head Lights which you do not have.
02-23-2015, 05:24 AM | #7 |
Rep 40,753
No, not possible.
02-23-2015, 06:28 AM | #8 |
Rep 634
Thanks guys.
I dont have adaptive headlamps so I guess they are just dummies and will never be used, unless it can be coded. I know there are normally US and Euro differences too. I.e on the e46 the inner fillament is DRL in the US, and the xenon is low and hi beams. I would have liked to have lo and hi beams in the outer filament and an extra hi-beam in the inner like on the euro e46. |
02-23-2015, 08:53 AM | #9 |
Rep 510
The cornering lamps turn on when you crank the wheel past a certain degree or turn on your blinker. I don't think it will turn on when you're in park.
It's definitely not a dummy light. |
02-23-2015, 09:22 AM | #10 | |
Rep 634
As of today I have yet to see a BMW with this feature, though I'm sure you have had this on BMWs in the US for years. I have never noticed any additional light when turning, with or without indicators on. I have driven cars with adaptive lights, and they will turn the low beams in the direction of the front wheels. Since I have a euro car I therefor believe that they have no function and a just a dummy to hold the inner halo. |
02-23-2015, 09:34 AM | #11 | |
Rep 29,202
02-23-2015, 01:10 PM | #14 |
Rep 634
First euro cars I saw with this was on MB E and C class after 2005.
They had this function on the fog light, I remember I thought they had a busted lamp for a while, before I found out what it was. First car I ever saw it on was an imported Ford Taurus wagon of the -92 to -95 body style. It had them fitted on the side of the front bumper. |
02-23-2015, 02:01 PM | #15 | |
Rep 18,713
Also, the other thing is, the cornering light on the F10 is just regular bulb. Oh well, it is not possible anyway as shawnsheridan stated.
02-23-2015, 02:22 PM | #16 |
Rep 2,323
What if you already have your fog light on?
02-23-2015, 02:39 PM | #17 | |
Rep 510
The cornering lamp is better than the fog lights because it's sitting at a higher angle. Higher angles isn't affected by terrain imperfection and elevation changes causing shadowy affects. Fog lights are mounted low because fog usually hover 12-18 inches off the ground. So it doesn't have to hit the fog and blind you like how your high beam and low beam does. But it will cause shadowy affects if the road is not smooth. Plus fog lights are usually aimed across rather than down. A cornering lamp would aim down giving you better visibility of what's immediately in front of you. Since the X5 sits much higher than a 5, the fog light can be used as cornering lamps. It won't be effective in a 5. |
02-23-2015, 02:48 PM | #18 | |
Rep 18,713
Well, if the fog light is on, then it will not function as the cornering light.
That is the case with my F15 X5. Quote:
Anyway, on the '14 and up, the F10 fog light is LED from the factory already. I believe on my E60, BMW was using the fog light for the cornering lamp also. But I might be wrong, it has been a while since I sold it.
02-23-2015, 02:57 PM | #20 |
Rep 2,323
I think it is another cost saving move by BMW to put the cornering light on the fog. With my F10, even when my LED fog lights are on, I still get additional lighting from my cornering lights.
02-24-2015, 08:29 PM | #21 |
Rep 697
Drives: 2013 535xi
Off topic, but I had a Mark VIII. Awesome car, until it wasn't! Pre-LCI headlights sucked, though.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
02-24-2015, 09:15 PM | #22 | |
Rep 1,472
Is/was this "optional", I was under impression that all F10s would come with adaptive headlights ? |
