2010 2011 BMW 5 Series Forum F10 Paddle Shifters? Who uses them!? |
10-24-2013, 08:03 PM | #1 |
Rep 1,250
Drives: 20' X3M CP
They seem alot better downshifting then up. I feel like there is a noticeable lag between shifts. I hit + from 1st to 2nd... and I hit the rev limiter almost every time.
Anyone experience this? Marc
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
10-24-2013, 08:43 PM | #2 | |
Rep 1,684
But, that's just a tranny program and not the per se rev limiter function. The auto tranny won't let you hurt the engine. Now, the rev limiter function kicks in and cuts the fuel supply if the engine overspeed limit is reached. Like if you were in neutral and you floored it for a while. But, to be clear, a manual shift override as a result of the threshold limit being reached does not involve the "rev limiter function" |
10-25-2013, 12:07 AM | #3 | |
Rep 1,250
Drives: 20' X3M CP
10-25-2013, 12:12 AM | #4 |
Rep 494
Yeah, the paddle shifters are slow. You just have to learn to pull the paddles at 6k or earlier, or just let the transmission shift when the engine hits max revs.
10-25-2013, 12:19 AM | #5 | |
Rep 1,250
Drives: 20' X3M CP
From a stop being in s mode is fine, because it actually lets you pull from 1st.. but even rolling at low speed ( 5mph or so) it goes into 2nd gear (s2).. thats why I even put it in M1 so i can do a rolling start in 1st.
10-25-2013, 12:42 AM | #6 | |
Rep 494
If one of those three conditions was true, you probably were hitting the rev limiter. |
10-25-2013, 02:04 AM | #7 |
Rep 1,250
Drives: 20' X3M CP
ahh, ok.. then I did hit it. because I was in Sports + with DSC completely off.
10-25-2013, 06:53 AM | #8 | ||
Rep 1,684
10-25-2013, 07:30 AM | #9 |
Rep 8,806
Mine feels the same way. On the LCI it is possible to hit the rev limiter because BMW changed it to not upshift on its own depending on which mode you are in.
It downshifts great with the paddles but I agree the up shifting is delayed when you are up there with the revs. It's quicker to just let the car do it on its own. I've only been using the paddles to help with the break in process.... Alan |
10-25-2013, 12:15 PM | #10 | |
Rep 29,202
10-26-2013, 03:55 PM | #12 |
Rep 1,250
Drives: 20' X3M CP
I did confirm I know someone asked, when you turn off DSC completely it takes car out of Sports or sports + mode.
So annoying I dont get that concept.
10-27-2013, 09:33 AM | #13 |
Master Of My Domain
89
Rep 669
The only time I use the paddles is when I see or pass a cop I pull back on the (-) paddle to drop down a couple of gears to slow down without hitting the brakes, thus not having the brake lights come on so I don't look so guilty.
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
