2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 550i n63 power record
      11-28-2016, 01:26 AM   #45
SLVSRFR
SLVSRFR's Avatar
Guam
245
Drives: BMW 550i
Originally Posted by ARC550 View Post
You need a Real* tune.
Or your Jb4 wires/device is in bad shape.
Or the injector
      11-28-2016, 09:46 AM   #46
badblack550xi
badblack550xi's Avatar
car most likely needs carbon cleaning.
2011 550i RWD 60-130 7.35
      11-28-2016, 11:28 PM   #47
Bowser330
Drives: i3 REX
Originally Posted by saleen751 View Post
Does anybody know which is bank 1 on a US n63? I'm getting a drivetrain error and the code that comes up is bank 1 misfire. I just changed all the plugs and coil packs 2 months ago. If I'm looking at the front of the engine I changed the first spark plug on the left side of the engine and it's still giving me the error. The drivetrain error comes on about a minute after I start the car without even driving.
Any update on this?
      11-29-2016, 01:35 AM   #48
saleen751
Drives: 2005 545i
Taking the car back to be looked at next week
      11-29-2016, 03:42 PM   #49
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
I had the TU and I was able to stack JB4 with tune. The only way to change boost was to open the little boxes and increase dial.
Also, the transmission will hold as its comparable to X5M... the Transfer case will Not. I broke my transfer case on dyno lol
So what would be a fix for this? Or just stay at the power were at for drive cars lol? I don't want to drop the money for the turbos and a tune if I already know the transfer case is gonna go in no time. Any way to unhook the AWD shaft and make it RWD without changing anything?
there are 4 fuses you can pull and it will be basically RWD,
      11-29-2016, 04:28 PM   #50
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
Unless something from the wet clutch forward is what is breaking, there's no point. All that power is still going through the transfercase then. You can disconnect the driveshaft or the front axles but all that will do is keep the power from going to the front, not stopping it from traveling through the tcase. The fuse as well just disengages the clutch for the front power transfer.
Only real way to make it a RWD car would be to get a RWD trans and driveshaft (unless they use the same trans housing for both which is unlikely)
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
NV GUNS57.50
      11-30-2016, 12:39 PM   #51
MavRick
MavRick's Avatar
688
Drives: My Wife's M
What is the drivability of these cars with so much horsepower? What are the pump gas numbers? Any CEL's? I definitely want more power for my N63 but I also want my wife to be able to drive it or to lose any great long distance characteristics that make it awesome on a weekend trip to the beach.
      11-30-2016, 04:13 PM   #52
badblack550xi
not something you would enjoy long distance, but you can always turn off JB4 and enjoy your long drive, or let your wife drive.
      11-30-2016, 06:12 PM   #53
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Any update on this?
this should give you all the info you need
bank 1 is the right (drivers) side of the engine
https://www.google.com/url?sa=t&sour...81gkxzsFPKs39A
      11-30-2016, 09:05 PM   #54
MavRick
MavRick's Avatar
688
Drives: My Wife's M
Ahhhhh. So this magic is all coming from the JB? I exchanged emails with Aldo and he said he would just need the logs to make the piggyback work with my Dinan tune. Having the ability to turn on 'kill' mode when I want is very attractive.
Excuse my n00b question...it seems Dinan's biggest gain is holding boost until redline. Can those properties be mated with Burger's more aggressive mapping to really wake the car up? Probably a question better suited for Burger, huh?
      12-01-2016, 10:42 AM   #55
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Other than running meth/water, is anyone lifting the engine, removing the intakes and walnut blasting these V8's? These aren't easy to access like N54's.
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      12-01-2016, 11:33 AM   #56
badblack550xi
everyone should do it if their car is close to 50k it will save a lot of headache and frustration. Average price from an indy shop should be $2000-$2500 bmw charges 10k.
      12-01-2016, 11:44 AM   #57
m5james
m5james's Avatar
I agree, our V8's are so much harder to access. I'm guessing you've had this done...is the same aluminum adapter used on the N54 fit into the N63 as well? I've got a friend who'll do my GF's N54 powered 535xiT for $250 with gaskets, but if I can the same tools can be used on my S63 powered X5M, I'd like to ask him.
      12-02-2016, 06:55 PM   #58
MattPro
MattPro's Avatar
Bank 1 is on the left side, bank 2 is on the right side when looking at the engine.
I know from adjusting my wastegates so many times haha. If you scroll down in your guide you will see a reference to the vacuum pump being on bank 1, and the vacuum pump is on the passenger's side.
http://3.bp.blogspot.com/-hV_Kxl53du...s1600/vac1.png
Thanks,
Matt
BMW Fault Code DB
NV GUNS57.50
      12-02-2016, 07:29 PM   #59
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Sorry, you are correct, I figured that out but forgot to update the post.
      10-12-2017, 09:14 AM   #60
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
How do you adjust the wastegates?
      10-18-2017, 03:59 PM   #61
m5james
m5james's Avatar
There are videos on YouTube.
      02-11-2019, 01:24 PM   #62
535_BiTurbo
Just got my car back from pure turbo, put down 640 whp and 680 tq.
2011 550i
Mod list:
Bad black n63 intake
Stage 1 pure turbos
Active autowerkes catless Down pipes
AEM methanol injection
Megan custom exhaust with x pipe and deleted resonators
Jb4
What would this setup trap??
How would it do against a 640whp 6spd 2014 5.0 Mustang with A Roush Phase 3 kit, Longtube headers, intake and custom VMP/Lund tune?
      02-11-2019, 03:03 PM   #63
badblack550xi
i don't think that car ran again after the issues, we are at around the same power on the alpina turbo car. 60-130 is 8.4 secs. not sure what 640whp 2014 mustangs do 60-130 those are most likely lighter cars.
      02-11-2019, 03:22 PM   #64
warpeacelove
Drives: 550i
Were you running METH also or were you just using a Tune + JB4 + Downpipes + E85 and upgraded turbos to achieve that power level?
      02-11-2019, 10:22 PM   #65
badblack550xi
Stage 3 tune, Jb4 stack, B6 alpina turbos, Alpina Intercoolers, intake, cattles DP, E30 mix.
      02-12-2019, 01:57 AM   #66
535_BiTurbo
hmmm not sure, I know the heavier 13+ GT500 with full bolts/pulley tune (~730whp) does 60-130 in 6.8s.
