2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 535i ZGM Coding Issues
      02-28-2014, 01:25 PM   #1
Art818
Sleeper (;
24
Drives: Glendale
I was in the process of coding the airbag module, during the coding session my car ignition automatically shuts off.
When i restart the coding process all over again, now ignition isn't coming on, Terminal 15 Displays (0 Volts).
I was doing research and somehow my 'ZGM Module' is not sending Voltage to 'CAS'
Is there a way i can send Volts manually to the 'CAS/ZGM' Module so i can continue the coding process?
What might have caused this problem? Or the ignition to shut off during coding?
Im using 'ICOM A2'
Follow Me On Instagram , Ill Follow you back!
IG = @isteeze
      02-28-2014, 04:26 PM   #2
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
Exactly what I'd be afraid of and why I'm not messing with this coding on my own. These cars are 100% controlled by software. You can easily get into this exact situation.
Best of luck. Isn't there a forum on Bimmerfest dedicated to coding....?
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
