2010 2011 BMW 5 Series Forum F10 How do I test exhaust flaps? |
01-25-2015, 11:19 PM | #1 |
Rep 1,407
Installed a set of m5 mufflers on my 550i. I reconnected vacuum lines via extra lines and a plastic connector. How can I test if they are operational while a stationary position?
Setup: M5 mufflers with vacuum lines intact Resonator delete with X-Pipe |
01-25-2015, 11:22 PM | #2 |
Rep 163
Have someone rev the car and stand behind it to see if they open. Im not 100% positive, but boost obviously kicks in when revving and they are actuated from that so it should work.
Did you use the x pipe from the M5 fatback?? or just used the m5 mufflers and had a custom x pipe put in |
01-25-2015, 11:34 PM | #3 |
Rep 1,407
I just had the mufflers installed after the stock 550i resonators and chopped off the stock resonator and replaced with an x-pipe.
Just want to make sure my new vacuum line connection works properly. |
