2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
07-20-2021, 12:42 AM | #287 | |
Rep 2,595
2015 BMW 535xi
08-03-2021, 10:29 AM | #289 | |
Rep 2,595
__________ Bit of an update on the G11 retrofit. I forgot to account for the 5mm spacers when test fitting the 343M's. 343M's do NOT clear the calipers by like 1-2mm, so you'll need 3mm spacers. I have them on order from Apex, so hopefully, will be able to finally tackle this in a week...
2015 BMW 535xi
09-23-2021, 09:39 PM | #292 |
Rep 2,595
Coding? There's no coding involved.
2015 BMW 535xi
09-24-2021, 05:48 AM | #293 | |
Rep 1,060
If you want to bleed/flush the whole system you'll need ISTA software or some other method of cycling all the ABS and traction control solenoids, but that shouldn't be necessary if all you did was change calipers. Unless maybe the car sat with no calipers for a long time and enough fluid leaked out that the reservoir went dry? |
10-16-2021, 08:11 AM | #294 |
Rep 24
Drives: G31 530XD G01 30iX
I can confirm, that g30 4 piston 374/36 caliper fits with 18inch rims that’s my video for confirm.
Peace |
10-16-2021, 02:19 PM | #295 |
Rep 112
Wow, that is a TIGHT squeeze! I hope the tire place was smart with where they placed the wheel weights, as I don't think you can get one between the wheel and caliper! At any rate, I'm sure folks will be happy to know they don't have to upgrade wheels in order to do this mod.
10-17-2021, 12:01 AM | #296 | |
Rep 2,595
2015 BMW 535xi
10-17-2021, 03:39 AM | #297 |
Rep 39
10-19-2021, 10:07 AM | #298 |
Rep 2,595
To be honest they look very very similar to the F10 M5 calipers.
2015 BMW 535xi
10-23-2021, 06:14 AM | #299 |
Rep 277
Teaser.
Encendido397.50 |
10-24-2021, 02:15 PM | #300 |
Rep 2,595
2015 BMW 535xi
10-26-2021, 09:37 AM | #302 |
Rep 2,595
Interesting! It looks like the biggest they accommodate is 350x34 rotors? Do they need adapters or are they bolt on?
2015 BMW 535xi
10-27-2021, 10:17 PM | #303 |
Rep 2,595
G30 brakes retrofitted. 376x36 front, 345x24 rear. Needed a 8mm spacer (plus accompanying hub extender) to fit under the 343M's, as the corner of the calipers kept touching the spokes. In hindsight, I wish I took these to a machine shop before powder coating and had them machine back the corner a bit more, since there's a solid amount of meat there still. Oh well. First impressions:
Feels really good, but in a very subjective way. You get a lot more braking power up front, so the brakes feel more responsive but also takes more conscious control. The original brakes are more progressive and so you can really modulate the precise amount of braking power you want for silky smooth stops, while the brembos can be a bit jerky. If you overreact on the brakes you can really jerk yourself forward due to the unexpected braking force. Personally, I prefer to get more braking power up front and then back off as I need it, but for instance my dad like to have less initially and then have it build as he pushes harder. To each their own. From my very crude test at 40mph, stopping distance is worse by a slight amount due to the increased weight.
2015 BMW 535xi
Blue Angel1042.50 |
10-29-2021, 04:45 AM | #305 |
Rep 277
10-29-2021, 09:23 AM | #306 |
Rep 2,595
Maybe around a 2mm clearance. Kind of hard to photograph properly.
2015 BMW 535xi
10-29-2021, 12:06 PM | #307 |
Rep 951
Those of us who did the X5m swap, had to use a 4mm spacer to move the caliper outwards, to ensure the rotor surface lines up in the center of the caliper as intended. Did you have to do a similar adjustment to line up caliper with rotor braking surface?
10-29-2021, 12:15 PM | #308 |
Rep 112
Hi Unspec, thanks for the update on your G30 mod! It seems like this takes a bit more effort than the X5M caliper mod, so can I ask why you went this direction instead of the X5M calipers? They do look really great, though!
