2010 2011 BMW 5 Series Forum F10 Brake upgrades from other BMW models on F10 |
07-06-2019, 09:51 AM | #133 |
Rep 112
370x24? The European 550i rear upgrade is 345x24, so what car are you looking at that has 370mm rotors that fit an F10?
07-06-2019, 09:59 AM | #134 | |
Rep 112
Regarding your question about using your F01 brakes, just so I'm getting this straight, are you asking if you can install front calipers/rotors from an F01 to the rear of your F10?! |
07-06-2019, 03:36 PM | #135 | |
Rep 951
hardparker300.00 |
07-07-2019, 10:15 AM | #136 | |
Father of Frankenfold
300
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
It's either the caliper carrier, or the brake mount tabs on the hub carrier have more axial offset. That's unlikely though, since the OEM wants to change as few parts between trim levels on the same model. Caliper/rotor swaps are easy and cheap and they recoup the costs easily on sale. Not so much if there are snowflakes that take a different set of hub carriers. You should grab some of those 370mm caliper carriers and find out.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
07-07-2019, 12:40 PM | #137 | ||
Rep 951
07-08-2019, 04:27 AM | #138 |
Rep 112
This is really interesting, as I didn't appreciate the Alpinas got larger rear rotors. However, instead of adding even more rotating mass to my car, I'm going to stick with the X5M fronts and 550i rears for now . . . at least that's what I keep telling myself.
07-08-2019, 10:31 PM | #139 |
Rep 951
Well I also think that the Alpina B5 Edition 50 used the X5M front calipers and rotors. They look identical and the size of the rotors also matches so you def have the right setup in front. I'm really just intrigued though as to what caliper and carrier combo the B6 took as normally I would have thought Alpina didn't design their own brakes and used from existing options within the BMW lineup.
07-21-2019, 09:27 AM | #141 | |
Rep 112
I then went to autotrader.co.uk and pulled up some 550i and 750i cars. Most had 19" or larger, but there was a 2011 750i with 18" wheels. https://www.autotrader.co.uk/classif...cb223jz&page=1 I then pulled up a UK-spec 750i on realoem.com to see if it came with any other front rotor option other than the 374 x 36mm . . . it did not. Therefore, I would say that the larger rotor set up will work with 18" wheels on an F10. For absolute clarity, I'm talking about the single piston caliper set up here, and NOT the X5M/X6M 4-piston caliper. I do not believe the X5M caliper will fit with anything smaller than 20" wheels. |
07-21-2019, 09:32 PM | #143 |
Rep 118
Have a Zimmermann part number for the cross-drilled rotors in 374x36? Any idea on price? I can find the non-CD version for about $200 a set but can't seem to find the CD set in the states. Thanks
07-24-2019, 12:56 AM | #144 | |
Rep 2
07-30-2019, 07:45 AM | #145 | |
Rep 112
It appears the Zimmerman p/n is 150.2947.52. Price is £178 each. I have no idea where you could source these in the US, but I can't imagine they'd sell them in the EU and not in the US. On that website, you can also get CD Zimmerman rotors for the rear F10 345x24mm set up, but you cannot get CD front rotors for the front 374x36mm set up (only for the X5M set up). |
07-31-2019, 12:25 PM | #146 | |
Rep 951
Please check this page for Brakes and Rotor sizes for x5m that is a direct fit for F10. https://www.realoem.com/bmw/enUS/sho...diagId=34_0976 I highly doubt the x5m caliper will clear an 18" wheel. 395x36 rotors are pretty big and you can see they are barely clearing 20" Alpina wheels. |
07-31-2019, 12:37 PM | #147 |
Rep 112
Good catch, as I definitely botched that reply to Fly335dGuy. I was thinking about the X5M rotors, but just realised he was asking about CD rotors for the smaller 374x36. The link to the Zimmerman rotors I used is for E70 X5M rotors. I have not found CD front rotors for the 374mm size.
Also, for further clarification, in my previous post to Porscha, I was not advocating that the X5M caliper would clear an 18" wheel. I was stating that the larger F10 caliper/rotor set up (single piston with 374x36 rotor) would clear an 18" wheel. |
08-03-2019, 09:22 AM | #148 | |
Rep 118
08-05-2019, 11:09 AM | #149 |
Rep 112
Fly335dGuy, you just jogged my memory about a company I found in California that sells CD/slotted rotors for F10s: https://www.brakenetic.com/
Worth looking into. The duties and taxes that I'd have to pay to get them shipped to the UK are far more than what I can get the Zimmerman rotors for over here, so I passed. |
08-12-2019, 09:10 AM | #150 |
Rep 148
Hello guys,
I had a question about brake upgrades on my 2012 528i xDrive. My car came stock with 17" rims and I have tiny brakes that really dont stop the car well enough. I hated my original wheels so I bought some 20's and I was looking to get bigger brakes. The problem I have is that I am using my oem wheels for the winter so I need brakes that will still fit inside the 17" rims during winter. I was looking to upgrade to either 535i brakes or 550i brakes depending on which of them will be able to fit within 17" wheels. I know that the rear brakes for the 535i and 528i are the same but the front rotors are about 18mm larger as far as I can remember. And I believe that the 550i rotors are about 12mm larger than the 535i. I believe the numbers for the front are 330mm(528i), 348mm(535i) and 360mm(550i). I also know that the rear brakes on a 550i are slightly larger than both 528i and 535i but I am not worried about those fitting as they are nowhere close to as big as the fronts. Please let me know if I am wrong about any of these numbers and if anyone can point me in the correct direction for a brake upgrade that would be great. Thank you! |
08-12-2019, 12:31 PM | #151 | |
Rep 221
https://f15.bimmerpost.com/forums/sh...6#post24350836
2011 F25 X3 35i |M-Sport Front Bumper Conversion|Largus Full Adjustable Coilovers|FTP Charge Pipes|Gutted Catalytic Downpipe|RB Oil Cooler Thermostat Delete|25 Row Oil Cooler|Custom Built Cold Air Intake|9"AEM Cone Filter Behind Kidney Grills With Outerwear|Precision Raceworks Coils|BM3 Stage 2 E30 Tune| BM3 Upgraded 8-speed TCU Flash|395mm X5M Front Brakes
08-20-2019, 02:36 PM | #152 |
Rep 1
Had this thread bookmarked for a while, shout out to everyone that's put in the work and research. Wouldn't have a clue otherwise.
Typically I made an error with this and mated 760i calipers with 550i discs, giving the attached result, with the caliper housing fouling the disc. Only by 1mm or so, I feel like the caliper could be easily spaced out but I'd rather not. I was considering my options but can't exactly send the discs and pads back, and I've found 550i calipers which I've ordered, so the 760i ones are surplus to requirements. If anyone is interested in me donating them to their favourite charitable cause, send me a message. |
08-24-2019, 02:03 PM | #154 |
Rep 30
nope, it does not fit. i tried. but it would look really cool.
