02-08-2016, 11:24 AM | #1 |
Rep 182
Aftermarket M5 Fender
I was looking for upgrades on some wheels. If anyone with a aftermarket can confirm the dimension and width of the aftermarket M5 fender that would awesome. I believe the dimension stay the same for the rear bumper as far as I can see, correct me if I'm wrong?
02-08-2016, 04:36 PM | #2 |
Rep 14,522
f10 width: 1860mm
f10 M5 width: 1891mm if you plan on upgrading the fenders you will need to upgrade the front Bumper to an OEM M5 bumper. also keep in mind that there are M5 style front bumpers that retain the normal 5 series fenders.
02-08-2016, 05:20 PM | #3 |
Rep 182
I think you misread my question. I already have the full conversion. I was curious if the aftermarket M5 fender have a different width or is it the same width just different look.
02-08-2016, 06:53 PM | #4 |
Rep 14,522
I posted the width also, u didn't mention u already did the conversion. like I posted, which conversion did you do? OEM M5 w/ wider fenders? Or M5 style normal 5 series? Figure that out first.
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg Last edited by lsturbointeg; 02-08-2016 at 06:58 PM.. |
02-08-2016, 10:20 PM | #5 |
Rep 182
I understand the OEM is wider. I have an after market kit completed kit with the fender also. I'm not sure if that fender is wider than the original or it just the same but with the M5 grilled lamp holes instead.
02-09-2016, 05:18 AM | #6 |
Rep 1,406
It's the same with holes for the grill vents. I have an aftermarket set installed on my 550i.
No one makes a full aftermarket m5 kit with wider fenders. Well there's actually 1 but they are a little on the shady side. |
02-09-2016, 06:56 AM | #7 |
Rep 14,522
See I know forum member ismet has the wider fenders to accommodate his 10.5" M510's when he did his M5 conversion
http://f10.5post.com/forums/showthread.php?t=1142324
02-09-2016, 12:28 PM | #8 |
506
Rep 3,469
I can't speak for the front, but I believe it is identical (OEM vs aftermarket M5 Fender) You might have to measure yourself.
Here are the rear specs: F10 Non M: F10 M5: I think the total width accounts for the mirrors so that 1" might be negligible. |
02-09-2016, 12:35 PM | #9 |
Rep 182
