2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BimmerTech - NBT coding via USB
      04-01-2016, 01:53 PM   #1
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
bimmerTech are offering idrive coding through the USB for the NBT option 609.
http://www.bimmer-tech.net/bmw-nbt-coding/
is this correct or April fool?
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      04-01-2016, 07:57 PM   #2
Nelson@BimmerTech
Drives: 2014 M6 GC
Correct
      04-02-2016, 12:35 AM   #3
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
nice one!
2014 M5
1999 E38 728i -sold
M235i - sold
      04-02-2016, 08:36 AM   #4
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
I just got sent my link to the file - so will download and give it a go. need to wait till beginning of May though to get back to the car.
2014 M5
1999 E38 728i -sold
M235i - sold
      04-05-2016, 04:28 AM   #5
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
has anyone carried this out yet?
2014 M5
1999 E38 728i -sold
M235i - sold
      04-05-2016, 05:18 AM   #6
labenzm5
Drives: E39 m5
I am wondering if this will allow me to use waze on my nav screen.
I'm buying for sure if that's the case. Can anyone confirm ??
Thanks
      04-06-2016, 03:34 PM   #7
Nelson@BimmerTech
Drives: 2014 M6 GC
Thanks
No, you will need our smartview mirroring unit.
      04-10-2016, 07:23 PM   #8
535d1420
Drives: 535d
Is there a way to reset to factory settings quickly if you wanted to?
      04-11-2016, 02:25 AM   #9
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Which settings?
      04-11-2016, 06:38 AM   #10
535d1420
Drives: 535d
Say you changed some coding things and something comes up with your car and you want to change back tomfactory coding after installing the usb stick. Is there a way to reset the codes to factory settings without bmw knowing it has been altered?
Thanks!
      04-11-2016, 07:07 AM   #11
ulker32
ulker32's Avatar
Belgium
Drives: F20 116D EFE
Just bought the video in motion coding, will test it later today
      04-11-2016, 01:18 PM   #12
Almaretto
Almaretto's Avatar
2374
Thanks!
I cannot speak for usb method, but VO coding with actual OBD2 cable and your computer will reset any coding back to factory values. $20 for cable and you can code everything you want and set back as needed.
      04-11-2016, 08:30 PM   #13
535d1420
Drives: 535d
will bmw know when they hook up their devices that I have been trying to code my car? I don't want to cause a huge coding issue which causes bmw to void my warranty.
      04-11-2016, 10:47 PM   #14
Almaretto
Almaretto's Avatar
2374
Then stay away from things like the modules with engine and brake changes and stick to things that do not compromise vehicle safety protocols.
BMW is more likely to reset car to factory settings or "accidentally" wipe your coding during necessary software updates than spend time and resources to forensically look through vehicle files of a every car that is in for regular maintenance without any major complaints.
      04-26-2016, 07:27 AM   #15
tcbrown76
Drives: 2016 340i M sport
How did it go? Has it worked? Curious as I am entertaining this as well instead of spending the time to code myself. Thanks!
2016 340i AW/SB RWD/MSport/THP/ColdWP/TechP/DriverAssistP/19" 442s
      05-03-2016, 03:35 AM   #16
ps888
ps888's Avatar
Taiwan
Drives: F10
Is it fix the gray navigation select ?i got a 528i aways get " the fuction error " then navigation turn to gray and i can't select it . BTW if i already locate a address that still working .
      05-04-2016, 01:14 PM   #17
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Done.
i got emailed a link to dropbox folder, download file to USB drive. insert in cars USB point in the arm rest for 3 mins. turn off car and remove. lock car up and wait 10 mins.
back in the car start up and hey presto changes done.
now have the enhanced BT, M sport displays, ///M idrive start up, compass option in display under xDrive, video in motion.
2014 M5
1999 E38 728i -sold
M235i - sold
      05-09-2016, 04:11 PM   #18
F30zoom
F30zoom's Avatar
Drives: F34 330d xdrive
Question
Originally Posted by Hasser View Post
Done.
Hi,
Planning to do this can you tell me what format you used for the USB stick? Fat32, NTFS, Exfat?
Thanks
      05-09-2016, 04:25 PM   #19
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
Done.
Hi,
Thanks
To be honest I down know.
I used a small external hard drive I had spare.
Some newer usb sticks don't work for some reason.
I tried a new sub 3.0 stick and the car didn't recognise it.
2014 M5
1999 E38 728i -sold
M235i - sold
      05-09-2016, 04:35 PM   #20
Almaretto
Almaretto's Avatar
2374
Originally Posted by F30zoom View Post
Hi,
Thanks
My guess would be Fat32 as that is what I format flash drives for Map updates via USB, but I use NTFS for external drives when I am playing music and videos.
Does product not come with instructions?
      05-11-2016, 12:43 AM   #21
Nelson@BimmerTech
Drives: 2014 M6 GC
Yes.
      05-19-2016, 10:33 AM   #22
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
I used this on my F10 today and did a whole raft of changes including Enhanced Bluetooth, took me less than 15 minutes including the 10 minutes wait between shut down and reboot. It's very simple and saved me a lot of time and messing so thanks and well done Bimmertech.
