2010 2011 BMW 5 Series Forum F10 Brake Force Display - BimmerCode |
02-28-2020, 12:22 PM | #23 |
Rep 5,406
Braking or HARD BRAKING? Normal braking won't cause the blink; it's designed for "panic" braking. The front doesn't nosedive during "panic" braking so the brake lights flash to let those tailgaters know that you're stopping rather quickly. There's an explanation somewhere...
02-29-2020, 06:34 PM | #24 | |
Rep 2,595
There's also a parameter that controls when the BFD turns off, determed by when your deceleration rate decreases to below a certain threshold. It needs to be coded to be lower than the activation speed if you code activation to be below the default deactivation threshold. The NHTSA study suggests that the largest benefit is activation at around 3.5m/s2, which corresponds to a werte value of 07.
2015 BMW 535xi
03-16-2020, 01:43 PM | #25 | |
Rep 75
Expert mode 3050 FRM_AU... blah blah blah ESS_ERSCHEINUNGSBILD THEN CHECK bremslicht blinkend code... done |
