2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BMW F10 strange whistling noise while speeding up.
      04-04-2024, 05:53 AM   #1
Wrohi
Drives: BMW F10 535I
Model: BMW F10 535I
Problem: while speeding up from stationary strange whistling can be heard, outside of car too.
Could this be a problem or just a turbo noise that's normal?
Adding YouTube video of the sound: https://youtube.com/shorts/ChJX7I7i9l0?feature=shared
      04-04-2024, 06:28 AM   #2
DementedF10
DementedF10's Avatar
Drives: 2012 BMW 535ix
I hear Nothing in that video but Turbo's make turbo noises. You should hear mine HAHA. Lots of whooshy and whistling..
      04-04-2024, 06:44 AM   #3
Wrohi
It's strange loud whistle that starts after like 2 seconds in the video
      04-04-2024, 07:09 AM   #4
smokinu454
Drives: 2016 535i
Doesn’t sound like turbo noise to me. How many miles on the car and what year?
      04-04-2024, 08:09 AM   #5
Wrohi
2016, 200k km (124k miles). Timing chain recently changed
      04-04-2024, 06:45 PM   #6
Wrohi
Up
      04-04-2024, 09:38 PM   #7
Conserve
Drives: 1976 BMW 2002 & 2015 BMW535i
I searched what you described and others have had this problem but unfortunately there are no conclusive findings. Some suggested to turn off the AC/ fan off, other one to switch center register between warm and cold settings. Last one is if you oil fill cap off. do you hear it.
https://www.google.com/search?q=BMW+...t=gws-wiz-serp
      04-05-2024, 02:23 AM   #8
Wrohi
I don't think it's about fans, because the sound "goes with engine", if the engine sound speeds up then the whistling gets louder, if gearbox changes gear, the whistling goes off for split second and than back again whistling until new gear, goes away at higher speeds.
      04-05-2024, 06:24 AM   #9
smokinu454
Drives: 2016 535i
Open the hood, remove the engine cover, start the engine, and see if you can hear it even faintly coming from the pcv in the valve cover. I had a b58 that sounded like this, wound up being a bad pcv diaphragm. Sadly if it’s bad on yours you’ll need to replace the entire valve cover. The b58 also had white smoke from the exhaust at idle with it.
      04-05-2024, 08:17 AM   #10
poverty.f10
DIY Mechanic
poverty.f10's Avatar
Drives: 2012 BMW 535i xDrive
Any type of whistling might be coming from the PCV. You could do the flame test or you could also test to see how much vacuum it has and see if it holds.
You can live in a car but you can’t race a house.
      04-05-2024, 10:29 AM   #11
s_ribs
Drives: '15 535i xDrive M-Sport, E30
Do you still hear this noise if revving the engine while stationary in Park or Neutral?
      04-05-2024, 02:33 PM   #12
Wrohi
Hi, tried it = nope, no whistling on N or P
