2010 2011 BMW 5 Series Forum F10 2013 N55 (535i) oil leak - where is it coming from? |
02-26-2018, 05:06 PM | #1 |
Rep 56
hey guys, I'm having some oil dripping onto the catalytic converter and causing a burning smell for a few minutes. I suspect it's the valve cover, but i figure i'd ask and make sure. A small puddle forms at the rear left of the engine and drips right onto the cat. if i just spray some brake cleaner on there it takes about 2-3 days for the problem to reappear. oil reading does not go down and there are no other issues. the car is a 535i with 85k miles with regular service. i use 5w30 with a quart of dura lube added every oil change.
have you guys changed the entire valve cover assembly or just the gasket? |
02-26-2018, 05:54 PM | #3 |
Rep 56
How many hours do you think it would take. I am technically inclined, but have never done a valve cover job. Do you recommend using oem or are the aftermarket ones ok as well? Any soecialty tools?
02-26-2018, 09:10 PM | #4 |
Rep 14,521
Also check out your oil filter housing gasket while you're at it as mine was leaking onto the belt which could have been a costly repair had i not repaired it
02-27-2018, 11:10 AM | #5 |
Rep 1,214
R&R of the valve cover / gasket on a F10 535i pays 5.5 hrs per KSD.
Factory gaskets and seals ONLY unless you want to first replacement for practice. |
musclesmarinara75206.00 |
02-27-2018, 04:18 PM | #6 |
Rep 318
Valve cover gasket for sure ! If your valve cover unit is not craked you may only replace the valve cover gasket. Go BMW OEM on all gaskets, last time I used a Victor Reinz vcg on my son's 335i was a total mistake and have to redo all the job 3 times. Don't forget to torque all the valve cover bolts at 8.5Nm in a crazy cross pattern starting at the back of the valve cover (where the leak has been detected).
(OO)-(////)(\\\\)-(OO)
'16 F22 M235i '19 G01 X3 | Wife's '15 F30 335i M-Sport | Son's '10 Porsche Boxster |
02-27-2018, 05:33 PM | #7 |
Rep 1,214
Doing the gasket only at your mileage is ill advised, take this from someone that does this for a living...
The valve cover should be replaced at age for several reasons. One, it is plastic and it cracks. Sometimes its cracked and that is why its leaking, and other times retorqing it causes it to crack, or best yet it will be fine for a few weeks and then crack... requiring a redo with considerable added expense. The valve cover has an integrated crankcase breather valve and the diaphragms do not last forever. I'm seeing more and more N55 valve covers coming in squealing with a failed valve. Save yourself the practice and just do it the best way the first time. Replace the valve cover as a complete unit. The new cover comes with the gasket and valvetronic seal. |
EL Jeffe 5612.50 JayBimmer8345.00 |
02-09-2019, 11:11 PM | #8 | |
Rep 590
02-11-2019, 11:08 PM | #9 |
Rep 14
Literally just went through this, it actually got to the point where i was blowing smoke through my ac vents. I moved back from Houston to NYC, drove the car up with no issues. I ended up changing the valve cover, gasket, walnut blasting valves, all spark plugs and one fuel injector. Not sure if its the plugs or the walnut blasting but car runs smoother and seems more responsive. I paid 2000 for everything all oem parts. I contemplated going aftermarket on the cover but saw nothing but horror stories.
If you havent already prepare to do the water pump, tensioner and belts as those are maintenance items that will be coming up. I had oil leak from my oil filer housinng onto my belts so i went ahead and changed them with tensioners since it costed a bit cheaper all together. Im at 96k now and owe about 5000 on the car so ill be keeping it for a while as a dd in hopes i can afford a gtr soon lol |
