2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications MHD Tuning Post Your Logs
      05-15-2018, 10:55 AM   #23
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Originally Posted by harris69 View Post
For some reason I am getting a lot of timing correction on cylinder 3 (as high as -5 degrees). I have brand new set of Bosch plugs too; so I am really not sure what's going on.
did you gap the plugs? you should try out what SC300T said and try the 91 oct map to see if the timing is ok
F10N557.00
      05-15-2018, 11:32 AM   #24
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
Plugs came pre-gaped or atleast that's what the mechanic said (Bosch 0242145518). I just filled up with 93 octane and I am going to log another run and see what it shows. Be back in a few..
      05-15-2018, 11:53 AM   #25
ey2001
ey2001's Avatar
310
reason I am asking is the ZR5TPP33S i bought the gap was not all the same...
F10N557.00
      05-15-2018, 12:49 PM   #26
harris69
I just Facebook messaged MHD and they advised me to run in 4th to 7000 rpms and shift into next gear for 2-3 sec and then stop the log. They also advised me to run 91 octane map if my car continues to pull timing.
Ey2001, I think they were all gapped the same if I am not mistaken. I am going to load up my log in a few.
      05-15-2018, 01:19 PM   #27
harris69
How do you gap the pre-gapped ones?
      05-15-2018, 01:22 PM   #28
ey2001
ey2001's Avatar
310
check with the gapper.. something like this
https://www.walmart.com/ip/Spark-Plu...&wl13=&veh=sem
      05-16-2018, 03:29 PM   #29
harris69
I think data logs are slightly better on this run.
https://datazap.me/u/harris69/log-15...27-28-29-30-31
ey2001310.00
      05-16-2018, 03:46 PM   #30
ey2001
ey2001's Avatar
310
yea looks better... did you change it out to 91 oct tune?
      05-16-2018, 03:52 PM   #31
harris69
Nope! Just logged more miles. I started data logging right after the tune and I guess it takes 50-100 miles or so for the vehicle to learn/adapt to new settings. I was going to tune to 91 but wanted to give it another chance to redeem itself before I tuned for 91 octane.
      05-16-2018, 04:14 PM   #32
ey2001
ey2001's Avatar
310
Nope! Just logged more miles. I started data logging right after the tune and I guess it takes 50-100 Mike's or so for the vehicle to learn/adapt to new settings. I was going to tune to 91 but wanted to give it another chance to redeem itself before I tuned to 81 octane.
nice!
      05-16-2018, 04:24 PM   #33
harris69
nice!
Do you see anything that should be of a concern?
      05-17-2018, 09:14 AM   #34
harris69
What do you guys think of this?
https://datazap.me/u/harris69/datalo...og=0&data=4-16
Finally!
      05-17-2018, 09:27 AM   #35
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
https://datazap.me/u/harris69/datalo...&data=4-16
Finally!
MHD Stage 2+ F10 N55 PWG.
Datalog 1-5 gears...wot
Boost Targets look low....
(No Boost Leaks .. was pressure tested )
https://datazap.me/u/ssgm1x/mhd-2-1?log=1&data=4-22
Does this look like Stage 2+ ?
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      05-17-2018, 09:38 AM   #36
ssgm1x
ssgm1x's Avatar
Finally!
Finally!
Some overboost and some throttle closures. Seems to be normal for all F10 n55 PWG cars to have this.
      05-17-2018, 12:31 PM   #37
harris69
I thought you were BM3, no?
      05-17-2018, 12:33 PM   #38
ssgm1x
ssgm1x's Avatar
Currently BM3. But also have MHD (was in their f series beta group ) and also have MP.
Have tried them all....
      05-17-2018, 02:07 PM   #39
harris69
Damn! Is there any tune you don't have? :P Is yours a 6-speed or 8AT? Can you do a pull in 4th (starting around 2500 rpms) to 7k and shift into 5th? I am trying how your tune stacks against mine.
      05-17-2018, 02:08 PM   #40
ssgm1x
ssgm1x's Avatar
Here was my MIssion Performance Log. A mild Stage 2 remap. At the moment I am working on a custom tune to resolve the PWG throttle closures/overboost.
https://datazap.me/u/ssgm1x/mission-...og=0&data=3-12
      07-03-2018, 12:10 PM   #41
ey2001
ey2001's Avatar
310
Originally Posted by SC300T View Post
http://www.georgebelton.com/E85Calculator.php
Maybe 2 gallons at most per tank full. 2 gallons will raise the octane a little over 1.5 points. If your 93 fuel is more like 91, this should clean it up. You could also run a 91 octane MHD map with your 93 gasoline to see if it cleans up - that may be the conservative way, and might not reduce performance much at all if you are getting pulls on 93, and also might feel smoother without the pulls.
are you using 91 octane?
      07-06-2018, 08:22 AM   #42
AlpineWhite_F10
AlpineWhite_F10's Avatar
17
Drives: 2013 535i M Sport
https://datazap.me/u/shotzz771/log-1...og=0&data=3-12
Stage 1 91oct - 8AT SAT Transmission
timings looks horrible, why? I think high IAT causes wrong timings..
also tell me please, if it has other problems and how to fix them..
Thanks
| Alpine White | M Sport | 535i | MHD Stage 1 | Eisenmann | IG: @AlpineWhite_F10 |
      07-06-2018, 09:30 AM   #43
ey2001
ey2001's Avatar
310
Originally Posted by AlpineWhite_F10 View Post
https://datazap.me/u/shotzz771/log-1...&data=3-12
Thanks
Yea your iat is really high... on auto you need to do a 4th gear pull full throttle and dsc off... also log the timing correction too.
      07-06-2018, 11:48 AM   #44
AlpineWhite_F10
17
Thanks for answering me, yes, it was from 4th gear and full throttle but in Sport+ Mode.. DSC wasn't fully deactivated.. also fuel consumption is too high... on dashboard it writes 8.8-9.2MPG with light foot always... it's real consumption, with half tank I can cover approximately 70-90 Miles... driving routine is approximately 10 mile per day..
