2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications MHD Tuning Post Your Logs
      07-11-2018, 10:20 AM   #67
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Originally Posted by dmorris30 View Post
Originally Posted by harris69 View Post
That looks really good (minus the early shifting) but I wish my logs were as clean as yours. I need to check my air filter, and once I replace my intercooler with an aftermarket unit I am hoping it will clean up my logs. Did you notice an increase in power with the VRSF chargepipe?
I was running out of road that can explain the early shift. my logs did not always look this good. Once I made the change to NGK 1 step colder new bosch coils and added some E85 that helped clean up the timing corrections i had with just 91 gas. I need to do a intercooler as well to help keep my IAT temp down. You really do not feel a power increase with a chargepipe i dont think. You really notice the differences in your throttle responses it responses a lot better once you step on it but that's just my opinion.
Didn't you have a dp also?
      07-11-2018, 12:48 PM   #68
dmorris30
dmorris30's Avatar
Drives: 2021 BMW G80 M3 Comp
Yes i did but i sold it, wasn't able to deal with the smell you get with no cats. looking for a catted downpipe and a few other things.
      07-12-2018, 06:38 AM   #69
harris69
Drives: 1997 M3/4, 1984 533i,1997 328i
Can you post the part numbers for your NGKs and Bosch coils? I recently had my plugs changed but I stuck with O.E Bosch plugs. Perhaps that's something I need to invest in...Did you do the plugs and coils in one go, or in different stages?
      07-12-2018, 09:10 AM   #70
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
I wonder if the bosch coils are better than the delphi. Amazon has the Delphi GN10571 Pencil Ignition Coil listed at $26.80 each.
      07-12-2018, 09:43 AM   #71
harris69
I hear the Eldors are the best- that's what BMW uses now.
      07-12-2018, 03:20 PM   #72
dmorris30
dmorris30's Avatar
The park# is NGK 97506 gap (.22) for the sparkplugs and the BOS-0221504470 for the coils. my car is very happy with that setup havent had any problems and I did the plugs and coils all at once.
      07-13-2018, 05:57 AM   #73
harris69
Thanks...Damn! I just checked on FCP Euro and these plugs run ~20 a plug...Would you recommend these on an otherwise stock 535i? (no mods except for MHD stage 1)
      07-13-2018, 04:49 PM   #74
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
Tried E30 for the first time and switched to an e30 map also. Not noticing much difference.... I guess i was expecting a lot more....a little disappointed to be honest. I Also had issues at WOT with car cutting out while on the e30 map. I guess it was too much boost for PWG Turbo to handle... not sure...
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      07-13-2018, 04:50 PM   #75
ssgm1x
ssgm1x's Avatar
i tried both bosch and the delphis...not much difference at all. Nothing noticable..
      07-14-2018, 07:49 AM   #76
harris69
They are both $27 a coil on FCP Euro. I am at 64k miles and am on original coils. How often, and when are you guys replacing your factory ignition coils?
      07-18-2018, 10:58 PM   #77
ssgm1x
ssgm1x's Avatar
Heads up on getting plugs.
If u look at the O.E. replacement Bosch plugs zr5tpp33-s they're R8 heat rated. But if u look at the Original BMW Bosch plugs zr5tpp33-s they are R6 heat rated. Both have the same part# from Bosch but one is BMW branded. very confusing.
I put the Bosch replacement plugs (R6 heat rated) in my car and BMW told me I had wrong heat rated plugs in my car. So I bought the BMW branded (R6) ones.
      07-18-2018, 11:12 PM   #78
ssgm1x
ssgm1x's Avatar
Try www.rockauto.com for NGK 97506 plugs. Cheapest around!!!
      07-19-2018, 07:57 AM   #79
harris69
I had mine changed with Bosch ones but I don't know if they were the original BMW, or Bosch branded ones. I am going to check my invoice, and see which ones are mine.
      07-19-2018, 08:00 AM   #80
harris69
FCP Euro has Lifetime Warranty on everything they carry which in my books is worth every penny. Also, their customer service is excellent.
      07-23-2018, 06:05 PM   #81
AlpineWhite_F10
AlpineWhite_F10's Avatar
17
Drives: 2013 535i M Sport
Hello everyone... today I bought bosch ZR5TPP33S for my car with MHD Stage 1 tune and gapped them on 0.022.. is this nice setup? or it doesn't needs that gap?
| Alpine White | M Sport | 535i | MHD Stage 1 | Eisenmann | IG: @AlpineWhite_F10 |
      07-23-2018, 10:43 PM   #82
ey2001
ey2001's Avatar
310
I left my gap the same... but like what ssgm1x said the heat rating is different... I too ended up just getting the OEM one from the Dealer..
      07-24-2018, 06:59 AM   #83
harris69
Cleaned out my intake box, and filter (it was a little dirty) but didn't have a new filter to replace it with. So for now it will do until I get around to ordering coilpacks, and sparkplugs.. Datalogged it this morning on my way to work, and it is still pulling timing...
https://datazap.me/u/harris69/july24?log=0&data=4-16
      07-24-2018, 07:31 AM   #84
harris69
Another one from yesterday:
https://datazap.me/u/harris69/july23...30-31-32-33-34
      07-24-2018, 10:01 AM   #85
ey2001
ey2001's Avatar
310
Did you try different gas? My last tank I put in it was pulling a lot of timing -4 -5... i think the gas was bad because I threw in 2 gallons of e85 and I had 0 timing pulls
      07-24-2018, 11:23 AM   #86
harris69
I fill up at my station so I know it's not bad gas.
ey2001310.00
      08-01-2018, 10:20 AM   #87
ey2001
ey2001's Avatar
310
How high does your IAT get? Whats the highest you seen in traffic?
      08-01-2018, 07:08 PM   #88
harris69
Mine? ~108 °F I think. When I am in boost I have seen it get up in the ~134-136 °F.
