2010 2011 BMW 5 Series Forum F10 Thrust Arm Bushing Upgrade |
11-17-2020, 08:49 PM | #67 | ||
Rep 305
11-22-2020, 01:14 AM | #68 |
Rep 2,591
Heads up folks, the turner monoballs are on sale for 15% off right now. Both installed versions and monoball-only ones. The RWD preinstalled is at a nutty 390, but the AWD is at 535... why?!
2015 BMW 535xi
burro_blasta129.50 Bmwdoubles_194.00 |
11-22-2020, 11:14 PM | #70 |
Rep 517
This is a worthy upgrade. The control at higher speeds is superb.
BPM Tuned, Advanced Fuel Dynamics, Paddoq Valved Exhaust, Paddoq Magnetic Paddles, EDC dampers, Dinan Springs, H&R Sway. DCT all day long.
https://www.youtube.com/channel/UCFu...fWjCtOz49FDMlg |
11-24-2020, 01:47 AM | #71 |
Rep 517
Now that I can confirm reducing deflection in the thrust arm has added a huge benefit I'm curious about caliper deflection. I check that the bearing isn't going by doing the shake the wheel test. Passed of course. Then I took the wheel off and shook the rotor to see if anything was loose there and I didn't notice the caliper moved a good amount. Coincidentally I ran across these on ECS and thought I might to try this before I go to the track. https://www.ecstuning.com/b-ecs-part...003326ecs01~a/
11-24-2020, 12:05 PM | #72 | |
Rep 2,591
Wonder if it's necessary for the rear calipers?
2015 BMW 535xi
Bmwdoubles_194.00 |
11-24-2020, 08:23 PM | #73 |
Rep 1,442
Drives: 2011 535i 6MT
Oh my gosh, stop already! lol. But as always... I'll wait for your feedback. It makes sense and I never even thought twice about the rubber... I guess I thought that was just part of the dust cover for the guide pins, I didn't realize that the guide pins actually RODE on that.
Let us know how they work out LOL Last edited by BimmerHausPerformance; 11-24-2020 at 08:28 PM.. |
11-25-2020, 08:49 AM | #74 |
Rep 2,591
I was tempted to get it, so I did more research and decided it wasn't worth it. I don't track my car, and it requires you to really keep on top of the maintenance of the bushing. You need to clean it regularly, since otherwise it'll bind up the pin. The OEM rubber is maintenance free, just needs the occasional replacement. The general consensus seems to be that the OEM BMW rubber bushings are pretty dang good.
2015 BMW 535xi
Bmwdoubles_194.00 Sylverlee150.00 |
11-25-2020, 09:52 PM | #76 | |
Rep 305
11-25-2020, 09:55 PM | #77 |
Rep 305
I really want to do my rear diff bushing but worry about diff whine like the e90 guys. Once installed please do a review for us.
11-26-2020, 08:47 PM | #78 | |
Rep 2,591
2015 BMW 535xi
11-30-2020, 02:42 PM | #79 |
Rep 1,442
So I just did the monoballs on the trust arms and wow, this is right up there with Coil overs and sway bars if you want more feel and control. I still need to test this out on dry roads but big difference noticed already on wet roads. I'm posing an install DIY video since I just got the bearings being the cheapskate I am. Good times.
12-01-2020, 05:38 PM | #80 | |
Rep 965
12-01-2020, 06:05 PM | #81 |
Rep 1,442
Don't forget to like and subscribe :-)
12-01-2020, 06:11 PM | #82 |
Rep 965
12-02-2020, 01:27 AM | #83 |
Rep 517
12-02-2020, 11:11 AM | #84 |
Rep 2,591
It sounds like it was just seized a bit. Tightening spec is 100nm + 90*, so it's not insanely tight. Penetrating oil + time + heat will probably help. Obviously, don't torch it if you're not replacing the whole arm :P
2015 BMW 535xi
12-04-2020, 06:13 PM | #86 |
Rep 2,591
It's here boys, time to somehow manage to hurt myself as I try to break that nut loose!
2015 BMW 535xi
12-05-2020, 02:15 AM | #87 |
Rep 517
You're gonna love them. It's one of my favorite mods I've done.
12-05-2020, 01:59 PM | #88 |
Rep 2,591
I already love them just by looking at it. Shiny blue, me like shiny.
2015 BMW 535xi
