2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Clogged Catalytic Converter
      11-06-2023, 04:11 PM   #1
itsnota2ma
itsnota2ma's Avatar
20
Drives: 2012 550i xDrive Msport
Okay, I am looking for your opinion. So, I just had my engine replaced on my 2012 550i w/140k miles and injectors replaced, because I had a faulty one. Now I have a clogged cat and my indie wants to charge me another $6400 to change the cats after I just spent $20,000 fixing the engine. So here are my choices:
1. Buy new OEM cats and install them myself - still like $4500.
2. Buy used OEM cats and install them myself - about $1500?
3. Buy new high flow cats and install them myself - don't know how much.
4. Buy new down pipes and install them myself - about $1500?
5. Get out while I can and take a loss.
      11-07-2023, 10:06 AM   #2
Jalumi69
Drives: 528i
Catalytic Converter Cleaning
https://f10.5post.com/forums/showthread.php?t=2044554
There is a PDF from BMW in that thread posted by @Hoa, on how to clean them - Worth a try as they are so expensive.
zrile91.00
      11-08-2023, 10:13 PM   #3
mcdanielvzw
mcdanielvzw's Avatar
144
Drives: 2021 X3 M40i (times 2)
I originally went for OEM 2.75" downpipes and the delete kit from ARM.
2 real issues:
-Install wasn't the worst thing I've done, but the heat shield doesn't fit 100% the way it did stock
-The delete kit moved the O2 sensors to a place that interfered with the stock airboxes..... Soooooo I ended up needing to also get a CAI that would remove the stock airboxes
No regrets here, and I don't have a light on 98% of the time (back-end O2 code still registers I believe) - I had an unrelated issue with low hydraulic fluid and the DSC system, but that was remedied. The car pulls noticeably harder and sounds great without being what I consider obnoxious.
Total cost would be about $1100 for the DP, Delete kit, and front facing intake kit. Labor not included of course, I'd recommend 2 people and a lift of some sort.
I'd presume, even to sell the car to recoup your money you'd need to do something with the Cats so it runs right.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
      11-15-2023, 07:46 AM   #4
itsnota2ma
itsnota2ma's Avatar
20
UPDATE: So after some searching, I decided to go with the high-flow Cats from Racing Dynamics. The price point was right, and I did not feel like farting around with the CEL for the O2 sensor. I am still in the process of installation. I was really concerned my independent mechanic mis-diagnosed the issue, because I could not see anything wrong, but once I got the one on bank 1 out, it was quite obvious. It sounded like it was filled with gravel.
So the Cats from Racing Dynamics come with a heat shield welded on. Do you think it is necessary to re-install the rear heat shields?? I will however, put the firewall heatshields back on.
Also note, cleaning was not an option here.
      11-23-2023, 08:04 PM   #5
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
Congrats on the New cats! are you going to tune it?
