2010 2011 BMW 5 Series Forum F10 To Avoid Headlights Water Condensation On Your F10, Read This |
12-23-2023, 05:38 PM | #1 |
Rep 97
So the headlights water condensation issue has been haunting the F10 since launch. There has been many reasons for this but since some models of the F10 now is older than 10 years old, it is bound to enter a workshop in your ownership for any reason. If you are planning to do something that involves removing the front bumper then you definitely want to read through this.
The F10 front bumper is fixed by many screws. Some on the wheel well, some under the bumper and some can be accessed from under the hood. As soon as you open the hood and remove the rubber seal that is on the edge of the top of the front bumper, you will see many screws but focus the the 2 screws on both ends. These specific screws fix the bumper on the top of the headlight housing and are shorter than the rest of the screws. Many shops whenever they remove a bumper, they mix the screws all together. So when they come back to install the bumper, they might install one of the longer screws on those slots and tighten them, THE SCREWS THEN PUNCTURE THE HEADLIGHTS FROM THE TOP and you can imagine what will happen after that. After a wash or a rainy day, you will notice condensation on the headlights and as time goes by, corrosion will start and eat up the internal of the headlight and modules and you will end up with thousands of dollars spent to replace them because of this stupid mistake. As you can imagine, this happened to me but thankfully the shop took responsibility of the mistake and compensated me fully for the headlights so I am good. Just wanted to make this post since when I got this issue started on my F10, I couldn't find any threads or posts mentioning this specific mistake which can burn a hole in your pocket. |
12-28-2023, 12:25 AM | #2 |
Rep 50
There are some pics in this post
https://www.bimmerfest.com/threads/h...-saga.1444527/ What year, model & trim is your car? I remember my pre LCI 2013 not sports bumper has all the same size screws. |
12-28-2023, 12:27 AM | #3 | |
Rep 97
01-03-2024, 11:13 AM | #5 |
Rep 2,591
All 6 bolts used for affixing the top of the bumper are part number 07147212669.
Anyone saying the two on the headlights are longer are either using aftermarket bolts, messed something else up, or just straight up misinformed.
2015 BMW 535xi
01-03-2024, 11:23 AM | #6 |
Rep 97
It may be correct but not all shops are organized as we wish. Most of the time if you got your car second hand, bolts (especially bodywork related) might not be the same as when you car came from the factory and are mismatched. Most shops just simply collect bolts all together when working on cars and reinstall them back as they see fit. The point of this thread is just to raise awareness on a mistake that any shop could make and to avoid people getting their cars ruined by careless shops. So no need for an attitude here.
01-03-2024, 12:43 PM | #7 | |
Rep 2,591
2015 BMW 535xi
Blue Angel1006.50 |
01-04-2024, 03:24 PM | #8 | |
Rep 28
And the shop still denied any wrongdoing
DBM
StradaRedlands4950.50 |
01-05-2024, 05:31 AM | #9 | |
Rep 1,039
Sounds to me like the shops doing the work are mixing up the screws from the fender with the screws from the rad support/headlights. I can totally see this happening - just another reason to be detail oriented while working. I bought a bunch of cheap magnetic bolt/screw “bowls” so I have no excuse not to keep fasteners organized while doing larger jobs. Hopefully I haven’t jinxed myself! This is also a good reason NOT to use power tools when reassembling small screws threaded into plastic. I can see a tech in a rush to get things done, just hammering these in with an impact driver, completely missing the feedback of the screw bottoming out in the hole and just cranking it tight. Thanks for the heads-up OP, I’ll make a mental check going forward. |
01-05-2024, 12:09 PM | #10 | |
Rep 2,591
I would be REALLY impressed if a body shop managed to confuse the fender ones with the top bumper ones - they're not even close when it comes to thread pitch. The bumper ones are machine thread, while the fender ones are a super super coarse thread - like, 1cm wide between each teeth. It would take a monumental amount of effort to thread them in. That said, possible, just I find it unlikely.
2015 BMW 535xi
01-05-2024, 12:40 PM | #11 | |
Rep 1,039
My first car needed the rear struts changed, and the mechanic forgot to put the nuts back on the upper mounts… the nuts, trim and speaker covers were all sitting in the trunk when I drove away. Since that time I’ve done pretty much every job except warranty work myself, and I’ve even regretted having warranty work done (water pump on my Cruze resulted in blown alternator, and mirror whistle on my wife’s E90 resulted in two bent wheels). I have several more personal stories, and have heard countless others. On that note, anyone who’s up for a laugh can check out the “Just Rolled In” YT channel for some hilarious DIY mechanic artistry. There are some creative people out there! |
