2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW M5 to F10 DIY Brembo Brake conversion
      03-19-2016, 09:16 AM   #23
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
any updates Mike?
      03-20-2016, 08:13 AM   #24
lsturbointeg
Originally Posted by mikekilpatrick View Post
They are still at the paint shop, I emailed them today actually. The weather has been too crappy to work on car.
what are you doing gold plating them?? tell them time is money!
      03-21-2016, 10:44 AM   #25
lsturbointeg
Well, I have the two sets of calipers being done. Painting the rotor hats, dust shields black, also have night vision front grill being painted, engine cover and hood release covers being carbon fiber dipped, and having the navigation screen cover being cf dipped. Also having the engine cover center portion shaved down and will be painted OEM outside silver and then painted with "Dinan Powered ///M". With the dinan lettering matching the intake stencil and then the ///M in OEM colors.
So, a whole bunch of stuff being done at once. Since the weather has been crappy, I have not been pushing them. Also, the CF dip was the wring style so he had to reorder another roll
I texted him this weekend and going to drive down there next weekend to see how things are going. My stuff isn't his only project as well.
interested in this CF dip...how does it work and where are you getting your stuff done?
      03-21-2016, 11:01 AM   #26
lsturbointeg
nevermind! i just Googled it and now you got me thinking some crazy ideas! damn you lol!
      03-22-2016, 05:04 PM   #27
lsturbointeg
South Jersey Hydrographics is doing the work. Looks just about Identical to real Carbon fiber.
Planning on doing the interior trim, mirror covers, side marker, reinforcement bar in the engine and maybe the steering controls
      04-10-2016, 12:22 PM   #28
Boss330
Boss330's Avatar
Originally Posted by lsturbointeg View Post
that's what i thought? i think i read somewhere someone just did the front upgrade but never the rear. after all is said and done are you going to have both front and rear calipers for sale or just the fronts?
The problem with just the front is that you are then still running small single piston rear calipers. The M5 rears are 4 piston and the rotors are drilled and ten you have Brembo all around, which I think will perform better and at least look better.
The M5 has single piston rear calipers just like all other F10 models.
http://teilecar.com/?2342,bmw-m5-f10...rembo&sLang=en
[IMG]http://teilecar.com/files/bmw-m5-f10...bo%5B10%5D.jpg[/IMG]
      04-12-2016, 11:53 AM   #29
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
Sooooooooo where we at?
      06-11-2016, 06:03 AM   #30
Noncom23
Noncom23's Avatar
Drives: 2015 535i
2015 BMW 535i  [0.00]
My paint guys at South Jersey hydrographics are finishing my engine parts over next two weeks. If they don't have my front grill, calipers and rotor hats done by may 1Rst I am taking them to another place to be painted. They got jammed up with work, but have had these parts for months now. Trust me,I just put my 265 Michelin. Super sport tired on the car two days ago, and I am itching to put the stinking rotors and calipers on. Then I am going to install dinan front and rear control arms.
Tell you the truth, the weather has sucked recently in NJ and I don't have a garage to work In. My garage is full of 7 rollaways and other tools
Any updates here, please?
Mike F
      06-11-2016, 08:50 AM   #31
lsturbointeg
+1! already been a couple of months Mike!
      06-22-2016, 02:27 PM   #32
lsturbointeg
Finally an update!
      07-18-2016, 04:59 PM   #33
mikekilpatrick
mikekilpatrick's Avatar
Got the Brakes back from paint FINALLY this past weekend. Everything has two coats of paint and 2-3 coats of Soft Clear Coat (same stuff put on bumpers). So nothing should chip now. Rear brakes were sanded smooth to match the Front Brakes in appearance. Rotors are sprayed and just enough metal sanded off so once the brakes start being applied, no rust ring will occur on these. ///M painted in OEM colors.
Dust shield for front painted in Black, again 2 coats paint and 2 coats clear with the soft rock absorbing clear. I only posted one set of brakes, but they all match and all the rotors match obviously.
Brake adapters are painted in Black too. So all of this should look sweet when looking between spokes of rims. Shooting for the next month or so to install. I need to dedicate a whole weekend for this and still need to order either OEM brake lines or after market stainless steel. Have not decided on that yet. Just need to sell the extra set of Calipers that I have for the front now. Only have 300 miles on them from a 2015 model.
      07-19-2016, 08:33 AM   #34
lsturbointeg
Whoa those turned out Bada$$! glad you did the shield black and not blue! Did you paints the hats too or did they come black? So these are the M5 Brakes? I gotta go back and reread the thread to catch up in things since you made us wait 10 years man they turned out really good!
BTW that's a floating rotor correct? Besides removing the calipers is it just a set screw holding the rotor in place? I ask because like I mentioned before I still have to paint my calipers and I wanted to paint the hats and the shield gloss black but I thought it would be cleaner if I just removed everything
      09-09-2016, 06:21 PM   #35
mikekilpatrick
Originally Posted by cipher5 View Post
While I'm not sure if the 550i one will work with the brakes, parts wise, the M5 does have a different Master Cylinder than the 550 (34336799903 vs 34336796729 respectively). Interestingly enough, the M5 master cylinder is used on the M5, M6, and the 640 and 650, but not the 550.
Interesting cross reference on REALOEM:
34336799903
5' F10   (06/2010 — 05/2016)
6' F06 GC   (10/2011 — 02/2015)
6' F06 GC LCI   (09/2014 — 05/2016)
6' F12   (03/2011 — 02/2015)
6' F12 LCI   (05/2014 — 05/2016)
6' F13   (03/2011 — 02/2015)
6' F13 LCI   (06/2014 — 05/2016)
34336796729
5' F07 GT   (03/2010 — 06/2012)
5' F10   (01/2009 — 06/2013)
5' F10 LCI   (08/2012 — 05/2016)
5' F11   (01/2009 — 06/2013)
5' F11 LCI   (08/2012 — 05/2016)
6' F06 GC   (05/2011 — 03/2015)
6' F06 GC LCI   (05/2014 — 05/2016)
6' F12   (10/2009 — 02/2015)
6' F13   (03/2010 — 02/2015)
6' F13 LCI   (05/2014 — 05/2016)
Looks like Overlap on certain years, which lead me to think they are interchangeable.
      09-13-2016, 09:01 AM   #36
SchillerM
Drives: 11' 550i, '00 M5, '11 E90 335i
Will be installing these 2nd or 3rd week of October. Been too busy with work to spend the time on the retrofit. So I will have them installed by end of October. I will be going to www.bmwtis.com for OEM install instructions and will post the procedure along with results.
I THINK Rheingold has same stuff as TIS? Can be downloaded if you look around (Check coding forums).
I can try to check this evening in Rheingold to see what it has for M5 brakes
Matt
      09-14-2016, 08:12 AM   #37
SchillerM
Mike, here are some screenshots I just took of Rheingold for an M5 front brake.
I have never used the TIS service, so not sure how it compares.
If you want me to check something specific let me know and I will see what I can find.
Matt
2011 Space Grey 550i - Eisenmann exhaust, ACS Springs, Dinan Intercoolers, Intake, & Stage 5 tune
2011 Space Grey 335i - M Performance exhaust - Wifes
Past: 2000 Avus Blue M5 - Dinan exhaust, flywheel, & tune 180k+miles
      02-20-2017, 05:32 PM   #38
oinkster77
Drives: E90 330d
Hi guys, does anyone have a 100% definitive answer on the M5 master cylinder, is it required for this mod
      02-21-2017, 12:20 AM   #39
mikekilpatrick
As soon as the weather gets warmer I WILL have the answer. Going to run the stock 550 Brake master cylinder and see how everything works. Others have used the 550 master with no issues.
      02-21-2017, 10:03 AM   #40
lsturbointeg
still don't have these on Mike?
      02-22-2017, 07:19 PM   #41
lsturbointeg
I'll save you the headache and buy those skirt extensions from you one less thing for you to install
      04-17-2017, 06:31 PM   #42
oinkster77
Drives: E90 330d
FYI the 535d master cylinder works perfectly with the Brembos
      04-18-2017, 12:20 AM   #43
mikekilpatrick
Thanks
Thank you for confirming that. I have done much research and all real OEM research shows cross compatible master on these but I was a little hesitant till confirmed. Now I can put this project on deck
      07-31-2017, 02:51 PM   #44
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
Just received the brackets from Russia today. BEAUTIFUL work and ONLY 440.00 SHIPPED in total!
can you send me his information? I'm doing the same process, does it come with brake lines as well?
BMW f10 550i Msport
