01-09-2015, 12:36 PM | #1 |
Rep 30
BOV or blow off valve
so i know that the f10 has a diverter valve or recirculating valve, but was wondering what options there are for venting into atmosphere. anyone know of anything. cant really find anything and im sure thats for a reason, but i like the whoosh sound if you will. i have the bms intake and enjoy the little bit louder whoosh it makes but really wanna here it. i know of some adapters but i am hesitant to buy them off ebay til i can here or know of anyone else having them. any info would be great.
01-09-2015, 12:38 PM | #2 |
Rep 30
http://thumbs4.ebaystatic.com/d/l225...J7DCLePMpQ.jpg
http://thumbs3.ebaystatic.com/d/l225...SNaePTZonA.jpg these are some i found...any info? |
01-10-2015, 10:36 PM | #3 |
Rep 14,522
Word is our car doesn't need it. I've also searched when I first got my car and seems like nobody does this. Never got a definite answer as to why?
01-12-2015, 07:31 AM | #6 |
Rep 359
It will disappoint you as the turbo sound will be reduced
On the otherhand Response will be faster Conclusion* A GFB TMS valve can help maintain bost pressure in the intercooler and pipes* whenever the throttle is closed with the following benefits:* Higher boost available upon re-opening the throttle for instant response* More boost throughout the spool-up process (up to 40%)* Shorter lag time (reduced by up to 30%)* No compressor surge* |
03-19-2015, 10:05 AM | #7 |
RELAPSED MOD ADDICT
179
Rep 432
i was always curious about this as well... i always wanted a BOV on that car but for the life of me cant figure out what steps to take to get it... any update on this
03-19-2015, 03:49 PM | #8 |
Rep 250
Maybe this? It does have F10 listed but who know if this site is legit or not. So who wants to be the first? lol
http://www.aliexpress.com/item/Savan...961448054.html |
03-20-2015, 10:39 AM | #9 | |
Rep 14,522
01-17-2021, 09:59 PM | #10 |
Cole
321
Rep 498
Even though this is an old thread, I thought I'd throw out to everyone that modifying the stock n63, n55,n54 or I imagine most n series divertor valves to vent partially atmospheric like the turbosmart dual port valve should be as simple as removing and drilling a few small holes in the right spots.
Has anyone tried this? |
01-18-2021, 07:11 AM | #11 |
Rep 1,230
you can always vent to atmosphere but keep in mind the car runs off recirculating air/maf sensor. You will throw whatever tune you have due the unmetered air.
N55 GENERAL
David Shoup Tuned Fully Built By Miami Engines/Project Motorworks Precision 6266 On Steroids |
01-23-2021, 12:08 PM | #12 | |
Cole
321
Rep 498
Changing from a recirculating divertor valve to venting atmospherically would have no affect on turbo sound while boosting. Unless I am misreading your comment here? N55 and n54 have many options for atmospheric conversions. I have seen adaptors/spacers that convert your stock divertor into venting atmospherically. I have installed these type of adaptors on other turbo cars with no issues. In fact turbosmart makes one. Google n54/n55 divertor valve atmospheric adaptor. Literally bolts between. OEM divertor valve and the turbo. |
01-27-2021, 03:22 PM | #13 |
Rep 14,522
i've installed the TurboSmart valve since last April and it vents half to atmosphere and half back into the system to prevent any issues. no problems til this day
01-28-2021, 02:25 AM | #14 |
Rep 262
I second the Turbosmart DV's, I just got them installed on my 550, completely new sound. Night and day difference in sound. I did DP's and upgraded turbos so can't say there was any gain from it.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
01-28-2021, 06:17 PM | #15 |
Rep 33
Drives: BMW 535I M SPORT
I used the GFB diverter valve on my f10 and their was no noticeable difference at all. just turbo noises. I ended up removing it, it gets annoying after a while. I personally wouldn't recommend it due to all the work you have to do to get to it.
2011 535i M Sport l ER Chargepipe l BMS Intake l Megan Racing Mufflers l RVG Catless Downpipe Subscribe To My Youtube Channel!! https://www.youtube.com/channel/UCuR..._as=subscriber |
01-28-2021, 09:35 PM | #16 |
Rep 14,522
the GFB sounds nothing like the TurboSmart
01-29-2021, 12:49 PM | #17 |
Rep 33
lsturbointeg9158.50 |
01-29-2021, 01:00 PM | #18 |
Rep 14,522
i have about 4 guys who have done this now and they all love it! 1 had the GFV and also said the TurboSmart sounds 10x better. as far as performance i feel it's holding boost better but i could be wrong since i had the GPlus Intercooler installed as well. but sounds wise you can't go wrong.
01-29-2021, 07:33 PM | #19 |
Rep 262
Here is a pic of my old ones out, pretty bad
2011 550i (N63)
02-03-2021, 10:00 PM | #20 |
Rep 262
TurboSmart Diverter Valves on N63 inside the cabin
2011 550i (N63)
06-02-2022, 10:59 AM | #21 |
Rep 36
why not try this
https://www.ssdd-motorsport.com/bmw-...valve-adaptor/
or https://www.aliexpress.com/item/2251...apt=4itemAdapt both will sound like turbosmart and way cheaper |
06-07-2022, 10:46 PM | #22 |
Enthusiast
312
Rep 281
Drives: 2025 M4 Comp xDrive
Getting my turbosmart BOV installed next week!
2025 M4 Competition xDrive
IG: Automaz_ |
