2010 2011 BMW 5 Series Forum F10 Radio staying on after engine off |
11-17-2013, 01:36 PM | #1 |
Rep 619
Just picked up my new F10, and have noticed that the radio/media stays on after the engine has been switched off, until I lock the doors?
Is there a way of getting it to turn off with the engine unless I manually turn it back on with the button? Cheers |
11-17-2013, 01:52 PM | #2 |
Rep 322
Hi Piers, this is normal. I'm not sure if you can easily change it. I found it a bit strange at first, but you quickly become accustomed to it.
Enjoy your F10!! |
11-17-2013, 02:34 PM | #4 |
Rep 29,202
Do you push the stop button a second time after shutting off the engine?
11-17-2013, 02:39 PM | #5 |
Rep 619
11-17-2013, 06:10 PM | #7 |
Rep 138
I find this annoying as well. There should be a way to have the radio turn off with the engine without hitting the button a second time. My car is a manual and if I still have the clutch depressed when hitting the button for the second time, the car will start back up. This should be configurable somehow.
11-17-2013, 09:01 PM | #9 |
Rep 553
You must either press the start button a second time (foot off the brake OR the clutch), or get out and press the lock button on the key fob or ridges on your door handle (if your car is so equipped), or wait ten minutes, or code your car with this:
- Turn off power (radio and iDrive) when opening door CAS=>3000=>TC_LOGIC_KLR_OFF_DOOR=>aktiv
Regards,
MWPos |
11-18-2013, 09:41 AM | #12 |
Rep 2,248
I just lock the doors after a single engine-off button press. Too often if I double press, I find I still have my foot on the brake. Then I feel like I was "punk'd". It's a dumb set-up.
11-18-2013, 09:42 AM | #13 |
Rep 2,248
This is not entirely correct -- the standard set-up does not include door unlocks. It doesn't matter whether they were set to lock automatically on driving, or locked manually.
11-18-2013, 10:11 AM | #14 | |
Rep 553
Regards,
MWPos |
11-18-2013, 06:47 PM | #15 | |
Rep 138
11-19-2013, 01:16 AM | #16 |
Rep 159
11-19-2013, 06:58 AM | #17 |
Rep 553
Most coding and mods that I do is from NA envy of EU car defaults!
(Except for that weird right-hand drive thing that you do)
Regards,
MWPos |
11-19-2013, 07:23 AM | #18 |
Rep 619
01-26-2015, 06:14 PM | #20 |
Rep 5,285
I have the opposite issue. I've spent hours searching the OM and online and I just can't seem to find the answer. How do I turn on the radio without turning on the car. This is my first push button car and I'm used to a key where one gets (usually) acc/off/on/start or off/acc/on/start. When I push the start button (foot off brake) the car is in the "on" function with A/C, lights, fan, etc. energized. I would like to listen to the radio while I'm waiting for my wife at the mall!! TIA!!
01-26-2015, 07:47 PM | #21 | |
A Man of Wisdumb...
28
Rep 114
01-26-2015, 08:41 PM | #22 |
Rep 5,285
