2010 2011 BMW 5 Series Forum F10 My 2011 535xi steering wheel retrofit |
11-10-2017, 04:16 PM | #1 |
Rep 1,873
Just a quick thread to document my very recent steering wheel retrofit.
I have a 2011 535xi with 205 (no paddles), heated wheel (248) and the base, thin, crappy steering wheel. I have no DHP handling, no COMFORT/SPORT switch, and I have the standard shifter. I wanted a retrofit and started putting together an LCI M-Sport option (with the little round airbag) but nothing affordable was coming together for the whole thing. I purchased a pre-LCI M5 wheel with tri-colour stitching, airbag and option 248 heat. 1/ disconnect battery negative terminal 2/ release airbag with slot head screwdriver through access hole in bottom of wheel 3/ disconnect main airbag connector. Be careful with the single yellow wire horn connector - you need to grab the little plastic loop and pull it TOWARD you (away from the dash). A lever will separate from the main connector and disconnect. It's really easy to mangle this connector trying to get it disconnected. 4/ 16mm bolt fastens wheel. Disconnect buttons and heater cable harnesses. 5/ reverse disassembly with replacement wheel 6/ snap airbag into place. 7/ power up the car 8/ Change VO 205->2TB. Write to vehicle and code to ICM and EGS. 9/ Go into SZL and look for Variantencodierung_2_2_1 and code to 'aktiv' So far, so good. The SZL coding was not in many of the guides. Even harder to find was the Variantencodierung_2_2_1 part - as opposed to paddle related values (which my SZL didn't have). |
11-11-2017, 08:02 PM | #2 | ||
Rep 77
What programmer did you use? |
11-12-2017, 02:19 PM | #3 |
Rep 1,873
No pics at this point. This wasn't meant to be a full step-by-step DIY guide and, in the end, it looks like any M5 steering wheel mounted in any F10
The modifications to VO and the SZL options were done with E-Sys. Some guides that I saw when preparing to do this said to add 2TB to VO and that was it. other suggested that you needed to be sure that ICM and EGS were coded with the new VO (no other changes to the options). Far fewer guides talked about coding SZL and in most cases they documented SZLs with coding options clearly referring to paddles. My SZL had none of those options, but I found one thread mentioning Variantencodierung_2_2_1 |
12-19-2017, 07:21 AM | #5 |
Rep 1,873
Uhm - I didn't order by part#. It was from a USA M5 with steering wheel heat,paddles and nothing else. Probably 32337845948 as found here:
http://www.realoem.com/bmw/enUS/show...diagId=32_1866 |
