2010 2011 BMW 5 Series Forum F10 FIXED! 2011 535i cranks, starts, then 3 seconds later shuts off! FIXED! |
01-15-2024, 10:34 AM | #1 |
Rep 6
My car is experiencing a very strange and unique issue that I cannot find any info on online! It will cold start without fail, but after it's fully warmed up, if I shut it off and try to start it again, it will start and run for exactly 3 seconds, then shut off as if I had pressed the start/stop button and completely turns off the car...engine off, no dash lights, and the steering wheel moves up out of the way! If I let it sit for about 30 minutes, it will start and run like normal again until it warms up, then it repeats the cycle. I have replaced the battery with a factory H9, coded and registered it. Voltage while running is 14.7 until it warms up then it drops to 14.1, and while driving under acceleration it drops to 13.5, then back up to 14.9 on deceleration. Please help!!!
01-20-2024, 05:10 PM | #4 |
Rep 5
Sounds maybe your fuel pump might be starting to fail.
StradaRedlands4950.50 |
01-20-2024, 06:48 PM | #5 |
Rep 172
Codes? Sounds like a fuel pump or sending unit about to go.
01-20-2024, 09:50 PM | #6 | |
Rep 834
If you cannot find ISTA, at least buy yourself a Foxwell NT530 BMW version scanner for $150 from Amazon. Don't chase "ghosts". |
01-23-2024, 10:03 AM | #7 |
Rep 6
Thank you all for your input thus far
UPDATE... I scanned it with my Autel and I get the following code in the CAS module AFTER the car is warmed up 930732 "Fault with engine starting during starter operation: relay sticking" Last edited by por924; 01-23-2024 at 10:11 AM.. |
01-23-2024, 06:13 PM | #8 | |
Rep 369
Drives: '09 E90 328i 6MT, '16 F10 535i
I'd agree with the suggestion of getting a BMW specific scanner, if not ISTA. At least you'll know exactly what's going on that way and fix the issue rather than throw money at random parts hoping it'll rectify your problem. |
01-24-2024, 08:03 PM | #9 |
Rep 6
I'm hoping so, I'd hope it was the fuel pump instead but I planned on upgrading to a walbro anyway so at least that will be new here shortly.
Yes, the behavior of starting perfectly fine (after fully warmed up to operating temperature, about 30 minutes at idle), running for 3 seconds, then shutting off COMPLETELY, back to back to back consistently, is mind boggling 🤯 I believe I have ISTA or INPA on my laptop (it's been a while) so I'll run a diag and update here. Last edited by por924; 01-25-2024 at 06:45 AM.. |
01-27-2024, 03:53 PM | #10 |
Rep 6
starter operation: relay stcking
Fault memory Fault description Measurement via readback line: Readback level > threshold high The fault is set as soon as the terminal control switches off terminal 15. code 12A308 Condition for fault identification Terminal 15 on Condition for fault memory entry Fault code entry is made after 3 seconds Action in service 1. Check function of starter relay If necessary, renew relay or CAS 2. If relay is OK, check supply voltage of the starter motor and replace if necessary 3. If the voltage supply of the starter motor is OK, check functioning of the starter motor separately and replace if necessary Note on effect of fault Starter motor turns in spite of missing activation (vehicle may Jump), ignition goes off i.e. terminal 15 is automatically switched off. After engine start by button operation, the starter motor continues turning briefly and engine stops Driver information Check Control message (21) Ignition fault! |
CrippledLucifer127.00 |
01-28-2024, 08:39 PM | #11 |
Rep 6
FIXED!!!
I replaced the starter with a NEW unit from FCP Euro and all is well so far! Thanks for everyone's help and input! |
