2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tire pressure
      02-25-2014, 08:16 AM   #1
Ryguy29
TrizzlemyniZzzlE3
71
Drives: Sparkling graphite m3 coupe
Tire pressure
Wondering what psi I should be running on my 20 inch falken 245/25/20
      02-25-2014, 10:21 PM   #2
snj1013
Drives: 2011 528i
Doesn't sound like a correct tire size for the F10 chassis? What car are the tires on?
      02-26-2014, 05:53 AM   #3
Ryguy29
TrizzlemyniZzzlE3
71
They are aftermarket rims that are on a 528
      02-26-2014, 08:42 AM   #4
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
You mean 245/35/20?
      02-26-2014, 09:59 AM   #5
Grover432
Drives: 2013 535 XDrive
Whatever is on the doorframe of the car is what the tires are supposed to be set to unless that value is higher than the maximum pressure allowed by the tire manufacturer
      02-26-2014, 10:51 AM   #6
Ryguy29
TrizzlemyniZzzlE3
71
I know it says it on the door but these are aftermarket wheels and tires , they are also 3 inches bigger than my stocks just looking for a good psi to run year round on the new wheels...
      02-26-2014, 11:11 AM   #7
Ryguy29
TrizzlemyniZzzlE3
71
Also yes edit 245-35-20 , sorry about that...
      02-26-2014, 09:53 PM   #8
Don Juan
Don Juan's Avatar
Drives: 2020 X7 40i, 2020 I3s Bev
I have 255/35/20 fronts with 40 psi and 285/30/20 rear with 38 psi
Ride is firm but not hard . Note i dont have rft
2023 I4 40 Msport White/red interior 19"Rims
2023 Ix 50 MSport Hraphite Gray.Oyster interios 22" Rims
Retired
2020 X7 MSport 40i
2020 I3s Bev
      02-27-2014, 11:47 AM   #9
Grover432
The reason the pressures are listed on the door frame is that the car has been tested to react safely and predictably with those pressures. The tire manufacturers always tell you to inflate the tires to manufacturer's specifications on the door frame. There isn't much discussion beyond that except if you are looking to run them lower to improve comfort on 21" wheels when the car is delivered with 19's as stock. If that is what you are after, 21" wheels with lower tire pressure isn't really the answer.
2013 535 X Drive, Alpine White/M Sport/Executive/Apps/Black Dakota/Fineline Anthracite
      02-27-2014, 09:47 PM   #10
TrimThis
Drives: '14 528
I run 245/20 and 285/20 with 35psi. Rides nice, but don't know about tire wear.
