2010 2011 BMW 5 Series Forum F10 F11 535d Suspension Overhaul |
03-16-2024, 02:00 PM | #1 |
Rep 7
Advice needed please from fellow UK owners and our terrible roads. Ive had the car for 6 months and it has done 118k now. I came from an A6 Avant BiTDI with 155k which had brilliant suspension and I did 80k in it, never replacing a part, so assume all original. Currently BMW is a bit of a let down.
The 535d is terrible and bounces and floats, with lots of knocks from front end and a sagging back end some day. I have begun the expensive job of changing parts, and fitted a good quality Meyle HD front arms and wishbone kit. This has helped a little, but still feels like much more needed. I plan on fitting some Koni Special Active dampers (formerly FSD). I was going to just go o/e but wanted to have improved dynamics without sacrificing daily abilities as it is a family car, so these seem to be good. Now, questions are: *Does anyone have experience of these *What alternatives are there *Do I keep standard springs, or what would you advise (dont want to go much lower) *What other parts would you change (top mounts, bump stops etc) Many thanks. Chris |
03-16-2024, 05:49 PM | #2 |
79
Rep 174
Not from the UK but NYC has pretty shit roads. I went with Bilstein B6 dampers. I swapped out the springs with Dinan ones as well but I am sure the stock ones would work with the B6.
According to TIS the front top mounts are one time use so I would swap them. Depending on the condition of thr rubber spring pads and bumpstops I would change them as well. Keep in mind a lot of thr suspension hardware is one time use so replace that as well. |
StradaRedlands4994.00 |
03-17-2024, 04:38 AM | #3 |
Rep 7
Thanks for reply. I think your advice on changing everything is good as i wont be doing it again.
What is ride like? Does it still have good compliance for daily use. |
03-17-2024, 10:02 AM | #5 |
Rep 7
Great. Thanks. I may keep standard M sport springs. Not sure if they deteriorate to same extent as damper so could possibly reuse. Air on back so only front to think about.
03-17-2024, 09:43 PM | #6 |
79
Rep 174
They absolutely don't deteriorate like the damper. The might sag over time with many miles but your more likely to see corrosion damage them before that.
