2010 2011 BMW 5 Series Forum F10 air conditioning - doesn't seem very quick to cool down |
05-27-2012, 09:07 AM | #1 |
Rep 5,089
Got into my f10 today where it was about 28c outside so ininterior was pretty hot inside (despite also having the climate comfort windscreen)
it a temperature of 19c selected on both dials, it seems quite slow to coll teh car down. the fan speed didn't seem particularly quick given I thought it would want to get down to the selected temperature as soon as possible. My E39 used to blow out air at quite a blast to achive that but the F10 doesn't feel very agressive in trying to get down to the set temperature. All settings were on auto. Is this common? |
05-27-2012, 10:56 AM | #6 |
Rep 15,858
I can imagine the latest systems are a bit more subtle than previous generations, all in the quest for better efficiency and less over consumption.
The MAX button will obviously be the fastest way to cool a lot of heat soak, as it trying to chill to the lowest possible temperature, not to a higher preset value. My car is sitting outside in direct sun, shaded temperature is reading 31C as I write. Even with the windows cracked down and sun roof tilted open, the interior surface temperature is over 45C (infrared thermometer check). Let alone the heat soak in all the components, from a day in the sun. That will need a lot of cooling down to reach 22C, let alone 19C. It is so different than our UK typical range of ambient temperatures, where there may only be a small difference from ambient to cooled temperature. Peter |
05-27-2012, 11:03 AM | #7 | |
Rep 2,612
Drives: F30 328i Luxury - Sport Auto
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
05-27-2012, 12:25 PM | #8 |
Rep 5,089
I think may be I need to ajust the fan settings, I thought this was only for 'manual' control but quick look at the manual suggest this can be used even in automode
05-28-2012, 02:14 AM | #9 |
Rep 3,016
Have you tried scrolling the thumb wheel between the two centre vents? If you turn it all the way to 'blue' it will reduce the temperature very rapidly.
05-28-2012, 02:56 AM | #10 | |
Rep 619
But also, even though you use Auto, you must also press the 'cold' button, or icicle picture button for this to really work... turns cold in seconds for me... and even in this 28 Deg heat we are having in the UK!
Sunset Orange G20 330e xDrive M Sport Pro - Tech/Pro Pack, Park Assist Plus
Bluestone G30 M Sport - Gone to Stud Alpine White F10 M Sport - Gone to Stud |
05-28-2012, 06:13 AM | #11 |
Rep 5,089
thanks, ys the centre dial between the vents was set to 'blue' and the icicle button was on ie the air conditioner compressor is engaged.
The temperature did cool down but it just didn't fee very agressive in getting that temperature down. My E39 would blast you until he temperature was cooled down inside and then teh fan speed would decrease. I though that with auto set, the fan speed would be normal an dthe he fan button was for manual overide. I just assume with auto , everything would be catered for you.(as per E39). Air didn't feel that cold , I can't belive that a 2 week old car would need regassing at this stage , so i doubt its that. |
05-28-2012, 06:41 AM | #12 | |
Rep 3,016
In my Sep '10 F10 I've never felt the need to have the fan above minimum, which means that, with the main temperature dials at 20 deg C, it's virtually silent and very comfortable; if I then want to fine tune the upper body temperature, I just tweak the centre scroll wheel. Additionally, even on the very hottest days, the cabin temperature cools down within just a few seconds after starting the engine. I have to say that the climate control in this car is the very best I've known and this leads me to thinking that you might have a problem. |
05-28-2012, 07:19 AM | #13 |
Rep 10,185
AUTO is never very aggressive
It usualy makes the duct temperature correct for what you have set and then the cabin cools down slowly. It will also not blow at the hardest speed through the dash vents. MAX will set the duct temp to the coldest so the cabin cools down fast and also closes the fresh air flaps so it is only cooling interior air. I suggest press MAX and let the cabin cool down, then go to Auto to keep it there. If you do not have a MAX button on your model, put the temps to their lowest position, manually select the dash vents and press the recirculate button to close the fresh air flaps.
BMW if you are reading, I need a job, Please. |
05-28-2012, 09:01 AM | #14 |
Rep 2,323
The new BMW's AC system is a bit weak, the AC system in my Audi and Lexus cool down the cabin much quicker. I find myself turning up the fan speed in the BMW just to keep the cabin cool, I thought auto mode is suppose to adjust the fan speed for me. Maybe the auto is being to conservative with the fan speed in an effort to conserve fuel.
05-28-2012, 02:55 PM | #15 |
Rep 5,089
well popped out in teh car for a short trip. About 25c outside but car had been in shade all day so not warm inside at all.
Tried the max button and its cold air so its not a case of regassing, the system works ok its just the logic behind the system that appears to be less aggresive that what I was used to previosuly on my E39. (I tell you that E39 was such a good car!) |
05-28-2012, 03:49 PM | #16 |
Rep 396
Two things:
First, the fan speed can be set to a higher level in auto mode - this tells the auto mode to be more aggressive - so if you have the fan speed set higher it will blast at the beginning (much like youe E39) and then drop down; Second, you can set up timed venting of you vehicle to push much of the warm air out of your car at specified time. Its called "Parked-car ventilation" Switching on/off directly 1. "Settings" 2. "Climate" 3. "Activate parked-car vent."
2011 535i xDrive, Dark Graphite Metallic, Veneto Beige Dakota Leather, Technology Package, M Sport Package, Executive Package delivered Christmas Eve '10, Mods - quad tips, 20% tint, JB4.
05-28-2012, 05:39 PM | #17 |
Rep 205
My 2012 520d M-Sport F11 - This afternoon about 25 degrees outside and quite warm in the car. With it in Auto Mode the fan started slow until the air got colder and then came up pretty fast to cool it down and then gradually dropped back, just as you would expect it to.
05-29-2012, 03:04 AM | #18 | |
Rep 3,016
05-29-2012, 09:16 AM | #19 |
Alpina Addict
Rep 101
Since lots of people are generally complaining about cold drafts from Air Conditions, it wouldn't surprise me that this perceived "slower" cooling down in Auto mode compared to other (older?) cars is actually fully intended by design.
There's still the manual "MAX" option for those who prefer a quicker (is it really?) cooling and don't mind the side effects of the AC going full blast. Personally, I've never used the MAX option in mine so far.
Current: 2018 Alpina B4 S Coupe AWD
Retired: 2011 Alpina B5 Biturbo, 2007 BMW 650i SMG Coupe |
