2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Pic Request - F10 with 21s and H&R Sport springs
      11-08-2012, 02:01 AM   #1
jbeemer13
Drives: 2012 BMW 535i, 2018 BMW M3 CP
2018 BMW M3  [0.00]
I finally lowered my car on H&R springs. Big Thanks to Joe and the crew at Performance Technic!!!
Next mod is going to be rims. Still debating on 20s and 21s. I think I am leaning more towards doing 20s since I think you need coilovers to make 21s look right. However I am still curious.... Does anyone have pictures of their f10s on 21s with H&R Springs. Please post them if you have them!
Thanks,
Jimmy
      03-29-2014, 08:20 AM   #2
llarssonn
Drives: F10 M-Sport
Very nice love the drop on the car, What is the drop on the H&R springs 35/35?
      03-29-2014, 11:19 AM   #3
Tulsadetail
Tulsadetail's Avatar
Drives: 2011 E92
Mine has H&R with 20s. Can't imagine 21s or the ride it would have.
      03-29-2014, 02:06 PM   #4
pkancel
pkancel's Avatar
Drives: BMWs
You are in Cali so at least our roads are good and don't have the potholes and mess of other states unless you drive in LA a lot. But I had 20s for a short time and went back to 19s mainly because my wife drives it most of the time. The 20s were perfect for me, look, handling, etc. As Tulsa said above, cant imagine 21s. There are a couple of guys on here with them but unless they are really light weight, I am betting the ride will be severely compromised/a bit too rough. As you likely know, the lower the profile tire, the less tire there is to absorb bumps, irregular roads, etc.
      03-29-2014, 03:02 PM   #5
RickyB
RickyB's Avatar
30
Drives: DGM 550i
Here you go.
DGM 550i
      03-29-2014, 05:11 PM   #6
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
What are your front offsets Ricky?
      03-29-2014, 07:33 PM   #7
RickyB
RickyB's Avatar
30
Drives: DGM 550i
They are 32. I have a 5mm spacer up front as well to experiment with them a little more flush. Although I am getting some rubbing pulling into places with an incline and the wheels turned. Very slight but I'll probably end up removing the spacers.
- Still can't find out the rear offsets. Called COR numerous times. Most likely a 40..
DGM 550i
      03-29-2014, 07:53 PM   #8
MELLOWYELLOW06
331
You think I'm asking for trouble?
I have 35 up front and ordered 10mm spacers making it a 25
Best in the rear should be 36
      03-29-2014, 07:55 PM   #9
MELLOWYELLOW06
331
My 20" were 25 ave had no rubbing at all
      03-29-2014, 11:29 PM   #10
RickyB
RickyB's Avatar
30
Drives: DGM 550i
Maybe lol. I only have the problem when the wheels are turned at a 45* angle or so and I'm going up or down a steep incline\decline. i.e. Where a driveway meets the sidewalk. Never had the problem before the spacers.
DGM 550i
      03-30-2014, 04:16 AM   #11
carchrism5
carchrism5's Avatar
Drives: M2, X3 M40i, 911
Here are some more. Ride quality with the 21s and springs is just fine. It has the electronic suspension so it can be put in comfort, but even with normal it is very good.
For more photos check here: http://f10.5post.com/forums/showthread.php?t=933952
      03-30-2014, 09:20 AM   #12
SDf10
SDf10's Avatar
90
Drives: 16' F80 YMB M3
21" is the perfect rim size for our cars. I used to have 20's and there is really no comparison. The ride in not bad, and 21's really compliment the drop with H&Rs.
      03-30-2014, 11:20 AM   #13
MELLOWYELLOW06
331
That looks hot
Absolutely right though
I live my 20s but the 21s set this car off
What are your front offsets?
      03-30-2014, 05:50 PM   #14
RickyB
RickyB's Avatar
30
Drives: DGM 550i
Also I think you have the 535 correct? If so, remember the 550 is much lower in the front due to the weight. You could be ok with a more aggressive stance.
DGM 550i
      03-30-2014, 08:51 PM   #15
jbeemer13
2018 BMW M3  [0.00]
I ended up going with 21s! Definitely the right choice for the f10. Ride quality isnt much different from stock. At least on California roads.
      03-30-2014, 09:15 PM   #16
pkancel
pkancel's Avatar
Drives: BMWs
Ok, I stand corrected, those three cars with 21s look incredible. Not that I didn't think they would look good, just the ride issue. if the ride is good, then even better because they look great. Thanks for ruining my 19s Had convinced myself they looked fine, especially since the wife is driving it mostly.
      03-31-2014, 05:04 PM   #17
MELLOWYELLOW06
331
I finally got the computer to work so here are the 21" pix.
Sorry for your confusion but
at least you will get a size that looks proper on our cars!!!
      04-06-2014, 08:12 PM   #18
lezz77
Drives: f10
does HnR springs drop a regular 550i m sport lower than a 550i xi m sport? or they both will havw the same drop?
      04-19-2014, 02:46 PM   #19
4DRS55
Drives: GTF80,718GT4,TVG80,G05X5
not sure about the 550xi but i know ACS will drop the 535xi lower than the 535i
