2010 2011 BMW 5 Series Forum F10 Wheel balancing weights... |
05-14-2016, 06:29 AM | #1 |
Rep 897
What do you think of the old foam being partially left on, wheel scratched and new weight put on top of old foam? Car is less than a year old and this is the first tyre change, so the wheel was as new. There are more scratches under the foam...
2017 M3 Comp Pack 450PS
2017 C63S T 510PS |
05-14-2016, 07:07 AM | #2 |
Rep 14,521
working in the tire industry years back it should be fine but if the shop is planning on rebalancing it it's a good idea to remove it especially if it comes up the stick on weights are going to be put back close or on to that location for proper adhesion.
05-14-2016, 07:13 AM | #3 |
Rep 897
This is how they left it after balancing it. I don't think they should scratch my wheels with a knife taking the old weights off?
05-14-2016, 07:17 AM | #4 |
Rep 14,521
i would use a blade to remove the rest of the foam if it's bothering you or if you just want to make it look cleaner. i would however be concerned that the last weight seems like it's pulled up a bit you know what i mean? doesn't look completely flat
05-14-2016, 07:20 AM | #5 |
Rep 897
Yes I know. I went back and made a fuss and was told that to remove the rest of the foam would mean scratching the wheel - which they already did - ended up walking away, so if the weight comes off I will go elsewhere. Just wanted opinions as I expected it to be perfect and they didn't seem to give a f... Lazy work in my opinion.
2017 C63S T 510PS |
05-14-2016, 07:43 AM | #6 | |
Rep 14,521
05-14-2016, 07:48 AM | #7 |
Rep 897
05-17-2016, 12:52 AM | #8 |
Rep 12
This happened to my friends Audi and he complained to head office. They said the weights should have been removed with a plastic tool to stop it scratching the wheel, consequently the tyre fitting company paid to get the inside of his wheels re-spayed.
05-18-2016, 08:07 AM | #9 |
Rep 96
It's laziness pure and simple.
A plastic tool should be used to remove the bulk of the foam, followed by isopropyl alcohol (or similar) to clean the residue. Too easy for the muppets to use a screwdriver and wire brush...
F10 LCI 535d (313PS) M Sport
