2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Tire filment question here.
      04-23-2014, 04:17 PM   #1
Mr.skytech
Drives: Point A to point B in style
Cool Tire filment question here.
I want to be able to protect my wheels by getting wider tires but I dont know if they will fit.
My current setup is 245/35 20 but I want to be able to use 265/35 20.
Will 265/35 R20 rub on my 2013 535 X Drive?
      04-23-2014, 05:41 PM   #2
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
245/35R20 Imperial /Metric
Section Width: 9.65 in /245.00 mm
Rim Diameter: 20 in / 508 mm
Rim Width Range: 8 - 9.5 in
Overall Diameter: 26.75 in /679.50 mm
Sidewall Height: 3.38 in /85.75 mm
Radius: 13.38 in /339.75 mm
Circumference: 84.04 in /2,134.71 mm
Revs per Mile: 777.51/mi
Actual Speed: 62.14 mph 100.00 kph
255/35R20 Imperial /Metric
Section Width: 10.04 in /255.00 mm
Rim Diameter: 20 in /508 mm
Rim Width Range: 8.5 - 10 in
Overall Diameter: 27.03 in /686.50 mm
Sidewall Height: 3.51 in /89.25 mm
Radius: 13.51 in /343.25 mm
Circumference: 84.91 in /2,156.70 mm
Revs per Mile: 769.58/mi
Actual Speed: 62.78 mph /101.03 kph
Speed Variance: 1.02% too fast.
Diameter Variance: 1.03%
265/35R20 Imperial /Metric
Section Width: 10.43 in /265.00 mm
Rim Width Range: 9 - 10.5 in
Overall Diameter: 27.30 in /693.50 mm
Sidewall Height: 3.65 in /92.75 mm
Radius: 13.65 in /346.75 mm
Circumference: 85.78 in /2,178.69 mm
Revs per Mile: 761.82/mi
Actual Speed: 63.42 mph /102.06 kph
Speed Variance: 2.02% too fast.
Diameter Variance: 2.06%
I think you will be better off with 255/35/20
Visually will look better than 265, not as swollen
265 needs 9" or wider rim
your speedo will be 1% off compared to 2% of 265 tire
