2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum BIMMERPOST Review: M550d xDrive [M Performance Automobile]
      02-26-2012, 03:15 PM   #1
southlight
Moderator / European Editor
southlight's Avatar
1512
Drives: X3M
Arrow BIMMERPOST Review: M550d xDrive [M Performance Automobile]
BIMMERPOST NEWS
15
COMMENTS
BMW M Performance - The Third Way
By Manfred Jerzembek
Photography by BMW
BMW is closing the gap between its most powerful regular cars and the M GmbH's ultra high-performance models. Under the "M Performance" moniker, a number of new vehicles will be released soon. Munich is starting out with several powerful diesel models, but gasoline-powered M Performance cars are sure to follow.
We had the chance to sample the M550d xDrive (official info thread) for an 85-mile drive, starting at the M GmbH's headquarters in Garching near Munich and leading to a nice, Bavarian lunch stop at Gut Sedlbrunn, north of Augsburg.
A first walk around the car reveals the subtle changes which set this M Performance model just slightly apart from the regular 5 series, while keeping a respectful distance to the M5. The M550d xDrive is equipped with the same aerodynamic kit and the 19-inch M wheels that are part of the M Sport package, but there are a few exclusive touches to this M Performance car. Instead of foglights, it's got a horizontal blade in the lower air intakes, painted "Ferric grey", and the outside mirrors are painted in the same color. And while the trapezoidal exhaust tips are identical to the 550i's, this is BMW's first diesel which doesn't sport round exhaust pipes. A discreet rear spoiler lip is standard. The overall appearance is far from ostentatious and fits the character of the car well.
Size:  6.4 KB Name:  t17.jpg
Size:  12.1 KB Name:  t18.jpg
Size:  10.3 KB Name:  t14.jpg
Size:  14.4 KB Name:  t15.jpg
Inside, we recognize many elements from the M Sport package, including the European-market "aluminum hexagon" trim, and the M Sport seats. Exclusive to the M550d xDrive are specific door sill panels, and a reshaped gear selector with an "M" logo. A push on the button starts the 3.0-liter turbodiesel, which emits a distant growl - and the unavoidable vibration of an oil-burner - at idle.
Stepping on the accelerator unleashes a remarkable 546 lb-ft of torque, which are available between 2000 and 3000 rpm; maximum power - 376hp - is reached between 4000 and 4400 rpm. The engine redlines at 5400rpm. BMW has achieved this power by installing three Borg Warner turbochargers - two small, variable turbine geometry high-pressure chargers, and one large low-pressure unit.
Size:  14.8 KB Name:  t2.jpg
Size:  17.6 KB Name:  t3.jpg
The intercooled system operates in a specific sequence: At low rpm, just one of the smaller turbos becomes active in order to optimize throttle response. From 1500 rpm up, the large turbo joins in and helps reach the torque maximum. Finally, from 2700 rpm onwards, the third turbocharger, mounted in a bypass tube, spools up and compresses the air before it reaches the larger, low-pressure turbo. Maximum boost pressure is 3.5 bar. The common-rail diesel injection system operates with a maximum 2200 bar of pressure, up from the 1800 bar which the twin-turbo 535d can reach. The 3.0-liter straight-six diesel engine received a significant redesign to cope with the massive power and torque.
Behind the wheel, seated firmly in the sports seats, we notice precious little of the complex turbo operation taking place under the hood. What we feel is an uninterrupted power trip: The M550d xDrive reaches 62mph in just 4.7 seconds, top speed is a governed 155mph. This car could go a lot faster, and you feel it, but the governor will remain in place "for the time being," says BMW. The engine's grumble is unusually sporty for a diesel - we have included a soundtrack -, but it does not come close to the silky, slightly nervous and altogether delightful frequencies emitted by BMW's straight-six gasoline engines. "The car is designed to offer forceful acceleration even when you are already travelling at high velocity," says Dr. Nikolai Ardey, head of BMW diesel engineering at Steyr, Austria. His credo: "maximum boost for maximum performance" - and it truly works on the road.
Size:  16.7 KB Name:  t11.jpg
Size:  16.6 KB Name:  t12.jpg
A ZF-sourced eight-speed automatic is standard. Eight speeds? Less could be more, but at least the shifts are seamless and unobtrusive. The slushbox remains discreetly in the background, and it's not as playful as the seven-speed dual-clutch transmission of the M5. Like its big brother, the M550d xDrive is equipped with hydraulic power steering - precise, nicely weighted, and far preferable to the electric power steering which comes standard on lesser 5 series models. The brakes are taken from the 550i, and the all-wheel drive system is calibrated to discourage understeering. But you can't help noticing this car's excessive weight: At 4,178 lbs, it is 220 lbs heavier even than the twin-turbo 535d xDrive, not a car known for its emphasis on weight reduction.
This M Performance sedan is resonably comfortable, despite the 245/35 front and 274/30 rear tires on 20-inch wheels which were fitted on our test car. BMW's chassis experts tell us that the Dunlop tires make for a better ride, but the Michelin tires which are alternatively offered are preferable if performance is your main focus.
One of the most impressive characteristics of the M550d xDrive is its efficiency: Despite its heft and its near-supercar performance, the car is rated at 37.3 mpg in the - admittedly optimistic - European cycle. In real life, you deserve congratulations if you get more than 30 mpg, but that's still a remarkable feat. There is an "Eco Pro" mode in the drive selector, which softens the car's responses, and a "brake energy recuperation" gauge on the dashboard. This car, after all, is supposed to be "socially acceptable" even in environmentally conscious Europe.
Size:  20.4 KB Name:  t5.jpg
Size:  13.5 KB Name:  t6.jpg
Size:  16.7 KB Name:  t8.jpg
Size:  16.0 KB Name:  t9.jpg
Will it be offered in the US, too? Sorry, no. The M Performance diesel - this engine is also offered in the X5 and X6 - is sold only in Europe, South Africa, and Australia. BMW explicitly rules out North America and Asia. But there will be other M Performance models with gasoline engines. At the Geneva auto show, BMW will show a near-production concept of a hatchback M135i, and it is strongly hinted that more cars will follow. In the future, a derivative like the Z4 sDrive 35is would surely be an M Performance model; there could be higher-powered 3 series models, and even a derivative of the 7 series is possible - not too soon, considering the success of the Audi S8 and the Mercedes-Benz S class AMG. There is justifiable hope to see a lot of M Performance models in the next few years - and while they are a significant step up from the regular BMW cars, the distance to the real M models will still be so great that there is little danger the Garching-designed icons will suffer any damage.
N57S Engine Details
      02-27-2012, 08:54 AM   #2
Black Flagged
Black Flagged's Avatar
Drives: M2C
Nice... look and stance! wish the D would make it to the states!
      02-27-2012, 09:20 AM   #3
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
Me want!! Best of both worlds. This M550d xDrive, seems like it will make a great dailey driver!
      02-27-2012, 10:09 AM   #4
bimmerJP
bimmerJP's Avatar
Drives: 2008 e90 335i
Location: Texas, the United States of America, Planet Earth, Universe
Want... Do want... Oh... America... Please...
      02-27-2012, 10:09 AM   #5
m balla
m balla
Slovakia
14
Drives: ///M
So the new M3/M4 will have the petrol version of this motor? So with the 80/100 difference of the last M series, should we expect 480/450 from the new M3/M4?
      02-27-2012, 10:32 AM   #6
aajami
aajami's Avatar
Drives: Space Gray '09 E92 M3
Ugh, I can't believe it's 220lbs. heavier than an X-drive 535d. Where are the lightweight cars, BMW? If the M Performance vehicles are intended to bridge the gap between the normal lineup and the real M cars, then this doesn't bode well for lightweight M vehicles anytime in the near future.
Otherwise a great a review, south. Is that spoiler the same one as on the F10M?
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem
      02-27-2012, 10:33 AM   #7
Mahzari
There's a small typo on the rear tire size (should be 275, not 274). Also, I did not know that this car and the M5 had hydraulic steering. After driving a F10 non-sport, my two biggest complaints were the lack of suspension control and the lack of steering feel. Can't wait to drive the new M5 when it hits the States
      02-27-2012, 10:38 AM   #8
Diver
Diver's Avatar
Drives: Black '12 135i - Sold
3.5 bar, impressive. Too bad it is not for the USA.
      02-27-2012, 10:44 AM   #9
Fugly M3
Fugly M3's Avatar
5071
Drives: 2023 M3CX
love the car and especially the engine, which they should put into the 3 and the 1, that would be incredible. however, i think we're seeing the beginning of the dilution of the M name/brand. will be interesting to see what happens going forward.
      02-27-2012, 10:46 AM   #10
paddyrx8
paddyrx8's Avatar
200
Drives: F30 320 MSport, Estoril
2013 320d M sport  [0.00]
2003 E46 M3  [0.00]
2004 M3  [0.00]
2006 E90 320D MSPORT  [0.00]
2005 E90 320i  [0.00]
M badge diluted.
I hate seeing BMW's which are not genuine M cars with a 50p (50 cent) ///M badge from e-bay stuck on the back. Now it seems BMW are doing it. The ///M badge is being diluted.
Most people get confused with the ///M badging on an M-sport, now we will have M-performance badging as well as the proper ///M badging.
I would like the ///M reserved for M1 (or 1M), M3, M5, M6 etc.
      02-27-2012, 10:47 AM   #11
InTheNightKitchen
Ignorance is Bliss?
InTheNightKitchen's Avatar
Drives: 1 of Many
Man do I wish I could drive one of these
      02-27-2012, 10:54 AM   #12
Bimmernerd
Bimmernerd's Avatar
Sweden
Drives: 530dM xDrive F11 2012
Several European countries will get it...but not the UK or US market. I think this is a big mistake by the guys in Munich!
      02-28-2012, 03:40 AM   #13
panicos81
panicos81's Avatar
Cyprus
212
Drives: a white bmw
2010 BMW E92  [8.54]
2007 e90  [0.00]
beginning? it began years ago, X5M, X6M now M135i.. oh well, whatever sells i guess.. i have a 320i and has factory M badges (actually had because i removed them all except the door sills).. anybody want to trade their door sills??
      02-28-2012, 01:51 PM   #14
datbimmerdoe
datbimmerdoe's Avatar
great review!
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM
      03-05-2012, 02:49 AM   #15
snipez999
Drives: X6M50d
The M purists would say delete the 1M from that list as it's not a 'proper' M engined car either.
I agree with abuse of the M badge, but only where it is thrust upon the rear bootlid. M Sport packaged vehicles come with small M badges everywhere and it is unreasonable to expect owners to reverse engineer them. However, stick one on the back of your 318i and it becomes abuse of power, literally! ;-)
Anyway, back to the thread. I'm booked in for a test on the X6M50d when it hits showrooms in June. Should be exciting (I currently have an X6, 40d). Though I am a little concerned about how they will fit all that model designation on the rear end LOL
      11-16-2017, 04:08 AM   #16
Dezy152
Drives: black BMW
Thanks for the info. Good review!
Tags
bmw m performance, bmw m performance cars, bmw m performance vehicle, bmw m performance vehicles, bmw m550d, bmw m550d review, bmw m550d reviews, bmw n57, bmw n57 engine, bmw n57s, bmw n57s engine, m550d, m550d forum, m550d forums, m550d review, m550d reviews
