04-16-2024, 01:44 PM | #1 |
Rep 9
M5 F10 Deka Clutch issue
Hi ,
I have M5 F10 , FBO , Forged engine , pure turbos stage 2 Around 7month ago i ordered Deka clutch stage 2 My garage installed it for me and after around 400km when i go back home from 30km trip i can't put R anymore it just trying to put R i hear loud knocking and trans go in N , i drive aroud town to check what happen and notice 1gear gonne as well so i back home and leave car to my garage next day , they dissassembly trans and found out the clutch is completly burned In december contacted the shop with i buy the clutch i explained the whole situation and they ask me to send back the clutch to deka i sended the burned clutch and in february i get new clutch not just plates as previous but now with basket as well (many thanks to Deka and the shop) Today i pick up the car with installed brand new clutch also i put stock map on the car to be sure nothing happen to clutch My home and garage is 30km away mainly highway i drive allmost all the time around 140-160 but at somepoint i pass car and put a little more power like really not much and then i notice when it downshift it think a second and after it engage clutch properly and start to give power so thats was strange so i repeated it again but this time i drive around 120km and put some power the car drop the gear but still think engage the gear a little rpm rev and engage second time the gear but now properly and then the car start to have some power but after the second time i get error trans temp too high so i slowed down and stoped at next gas station it was around 5km Checked codes i get Clutch temp - phase red Clutch temp - phase black It was just 30km after installing new clutch Any idea what can be wrong? |
04-18-2024, 04:37 AM | #3 | |
Rep 9
Car was changing gear fine in town driving , problem start on highway speed I put BMS Oil pan for trans better cooling , is this can cause problems? Low oil pressure under load? |
04-30-2024, 02:26 PM | #4 |
Fueled by Recycled Dinosaurs!
632
Rep 1,175
Drives: F06 M6
Just had a similar issue with my S2 Deka Clutch driving from Tampa to Orlando. By the time I came to a stop and pulled in the driveway I only had 1st gear.
05-03-2024, 07:33 PM | #5 |
Rep 9
Im now after 400km
Upshift get better , little knocking but except that is fine The issue is downshifting it feel like the clutch get engaged with delay and this cause slipping I gonna make another 400km trans adapt and then will check how the clutch behave at WOT |
TinCanSailor631.50 |
Yesterday, 06:54 PM | #6 |
632
Rep 1,175
Drives: F06 M6
I had my car towed back to Midnite Tuning to let them spend some time with it. I was having issues with downshift, seemed to skip odd numbered gears, but was also having some hard upshifts and an awful sound which I think came from the transmission.
I don't think they have started any work on it yet and since I am out of town for work for a couple of months it isn't a must have priority for me. Looking forward to hearing more about your progress. Have you had any custom tunes done for the engine or transmission?
2015 F06 M6 Silverstone Metallic II, Individual Full Leather, B&O, Night Vis, CCB, RKAutowerks (CP Rods/Pistons, DI Cams, CF Intakes, Coated DP's & Billet Diff Brace), InfinityAuto Turbo Inlets, Mishi Oil Cooler, JB4, XHP S3, BM S3
Today, 09:12 AM | #7 | |
Rep 9
Im now after 700km on the clutch and upshift improved , upshift on low speed is like stock but upshift on WOT sometime feel harder from stock but it improved a lot from installation time The issue is on downshift , clutch look like slipping : If on 5gear and drop it to 3 with accelerator pressed the clutch start to slip for a second untill it engage properly , it feel like there is delay in engaging the clutch , i drive with ISTA connected to check the clutch temperature and clutch overheat very fast if i downshift like this , is enough to repeat this 2 times and i get temp warning But if on 5gear and downshift to 3 but when downshifted to 3 gear the accelerator is not pressed for around second it look like it have time to engage the clutch and then the slipp and overheat dont happen Also i checked and overheat not happening on upshift only downshift What clutch do you have? Any mods? |
