2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 20" wheels
      12-06-2016, 10:40 AM   #1
q94f10
Drives: retired: 2015 M6 GC
20" wheels
I have a 535 with the m sport 19" wheels. I was wondering if 20" wheels with tires size 295-30 in the rear and 265-30 in the front will fit without rubbing or any other issues?
Thank You
Ickdeep5715.50
      12-06-2016, 11:38 AM   #2
jjh2oman
jjh2oman's Avatar
Drives: 2014 BMW 550i
Thank You
Initially thought they would rub, but some people run them with certain offsets.
Just a squirrel trying to get a nut
      12-06-2016, 12:06 PM   #3
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
Thank You
Depends on the offset, it can fit.
      12-06-2016, 11:45 PM   #4
q94f10
Originally Posted by jjh2oman View Post
They'll likely rub both front and back.
Which size do you think will be the most I can fit on the front and rear without rubbing?
      12-07-2016, 01:29 AM   #5
jjh2oman
jjh2oman's Avatar
It is possible as I looked a little more into it that some folks have fit 265 and 295 widths, that's my mistake. However, you'll definitely want to post your offsets because other folks have rubbing on the same tire width with different offsets, so it can be very close at that size.
One other thing to consider is if you have x drive you'd be best sticking with tire options that preserve close to equal tire diameter. You can pretty easily fit 245/35/20 + 285/30/20 most of the time, which is a popular choice for X drive. Also, 255/35/20 + 295/30/20 might work with the right offset in back. Non X drive, not as much of a worry in regards to keeping the diameters between front and rear equal. Hope that helps.
      12-07-2016, 11:45 PM   #6
q94f10
Thanks a lot. This will definitely be useful in determining which style 20" inch wheels i get.
      12-07-2016, 11:58 PM   #7
jjh2oman
jjh2oman's Avatar
Glad to help, I've just gone through the same thought process for my car. I ended up with 255 and 285, which is ok because I'm not an X drive, on 20x9 ET+32 and 20x10.5 ET+45.
      12-13-2016, 02:57 PM   #8
The_M6
The_M6's Avatar
Drives: 2013 M6
Can you post a pic of the 255's up front? My wheels are 20x9/20x10.5 and while I know most are running 245's in the front, the roads here in the DC area really have me considering 255's. I already have the rear 285s and the wheels, just can't decide on the front tires because I don't want them to look overly "meaty"
Project Gamma Intakes / Project Gamma Catless Downpipes / Muffler Delete / DME Stage II Tune / H&R Springs
      12-13-2016, 02:58 PM   #9
jjh2oman
jjh2oman's Avatar
I don't have them mounted yet, need to find time in the next 1-2 weeks.
The_M6248.00
      12-21-2016, 07:44 AM   #10
The_M6
The_M6's Avatar
Drives: 2013 M6
255/30 is perfect on 9" wheels.
      12-22-2016, 10:59 PM   #11
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
I just installed oem 601m setup 265 front 295 rear and it's a perfect fit. No rubbing no spacers.
[IMG][IMG]http://i65.tinypic.com/125gaav.jpg[/IMG][/IMG]
[IMG][IMG]http://i63.tinypic.com/i3w3ls.jpg[/IMG][/IMG]
      12-24-2016, 11:54 AM   #12
exia_m3
exia_m3's Avatar
181
Drives: 2017 F80 ZCP MW/SO
2013 BMW E92 M3  [0.00]
2017 F80 M3  [0.00]
I ran 20x9.5 et 22 245/35 20x11 et 40 285/30 I could of ran the 255/30 but didn't liked the slightly stretched look
Current: 2017 F80 ZCP MW/SO @EnzoRacing PTF BM3 STG 2 GTHaus Meisterschaft GT2 Exhaust SSR Intakes
Swift Springs
@drivingwithbenny
      12-28-2016, 08:37 AM   #13
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
I'm currently running that M5 tire set up now with no issues on my wheels
20 x9 +35
20 x 10.5 + 40 .
No rubbing at all.
      12-28-2016, 08:38 AM   #14
dadysev
dadysev's Avatar
Montenegro
169
Drives: Man
sorry the fronts are 265/35 not 265/30 . My bad
      12-28-2016, 04:34 PM   #15
jjh2oman
jjh2oman's Avatar
20 x9 +35
20 x 10.5 + 40 .
No rubbing at all.
Yeah, I know, I corrected myself a few posts later saying that some people run the 265/295 combo just fine. It all depends on your offsets at that width.
