2010 2011 BMW 5 Series Forum F10 Steering wheel control unit - LCI Retrofit |
03-18-2015, 10:22 AM | #1 |
506
Rep 3,469
I recently installed a LCI MSport/M5 steering wheel into my pre-LCI F10. Everything works except the heat (both wheels are heated).
My question is, does the steering wheel have 1 control unit or 2? I see 2 different control units on realoem.com : (these are specific to my features, heat, no lane departure, no vibration) 61319218380 (didn't buy this one) - thinking this is pre-LCI control unit but not sure 61317848638 (only installed this one) |
03-18-2015, 10:38 AM | #2 | |
Rep 10,185
61317848638 is installed only in LCI with M Sport wheel An LCI with M Sport wheel will only have 61317848638 installed according to ETK
BMW if you are reading, I need a job, Please. |
03-18-2015, 10:56 AM | #3 |
506
Rep 3,469
Great, looks like the previous unit is only for non Msport wheel.
03-18-2015, 11:30 AM | #5 |
506
Rep 3,469
I went from pre LCI wheel heated
to Msport/M-6 Wheel (with the M6 wheel trim) - Heated I added paddles (need that coded) I haven't been able to get the heat to work on the new wheel, but I also have a plug that is not connected off the control unit. I already have the wire from the heating element going to the control unit, but maybe that small connector needs to go somewhere and I just didn't see it. In the diagram below, part 3, small connector on the top right is not plugged into anything. Full Parts List: 1 32-30-7-846-035 M SPORTS STEERIN 2 32-30-7-848-270 COVER FOR STEERI 3 32-30-7-846-029 DECOR TRIM COVER 4 32-30-7-848-330 CONNECTING LINE, 5 32-30-7-848-333 SET OF SCREWS 6 32-30-7-845-796 AIRBAG MODULE, D 7 61-31-7-847-210 SET OF ROCKER SW 8 61-31-7-849-407 SWITCH, MF STEER 9 61-31-7-848-638 CONTROL UNIT, ST |
03-18-2015, 01:16 PM | #6 |
Rep 18,709
cipher5 , that small connector from #3 that is not plugged, most likely is for the Lane-change warning.
I just did mine from LCI luxury line steering wheel non-paddle shifter to M Sport steering wheel with M trim and paddle shifter.
03-18-2015, 02:16 PM | #7 |
Rep 10,185
Does the heating button light up when you press it ?
Then just no heat on the steering wheel?
03-18-2015, 02:47 PM | #8 | |
506
Rep 3,469
Correct, the button lights up but there is no heat to the wheel. I read somewhere that even if the fuse were blown, the steering heat lights up regardless. I may pull the out in the next day or two and reseat the connections just to be sure. Maybe it is just loose. |
03-18-2015, 03:02 PM | #9 |
Rep 18,709
cipher5 , no, mine is not heated.
03-18-2015, 03:26 PM | #10 |
Rep 1,314
Im interested in doing this as well. keep us posted on the heated steering wheels as this is an option id like to keep.
also, if you dont mind, how much did this swap cost you? did you buy all your parts from tisher bmw? |
02-11-2016, 10:03 AM | #11 |
Rep 572
r33_RGSport I see you have combined the m5/m6 trim with the buttons from a non-m5/m6 as you don't have the m buttons. Is this also a m5/m6 steering wheel (3 colour stitching)? did you use non-m5/m6 electronics (ecu, cabling, harness)?
Daily: Porsche Panamera 971 | BMW 520xD G31
Sh!tbox: BMW Z4 M E86 | BMW 1M E82 | BMW M3 E90 Insta: bmw.shitbox |
02-11-2016, 03:01 PM | #12 | |
Rep 18,709
PM me with the last 7 of your VIN if you are interested in doing such retrofit.
08-24-2022, 12:24 AM | #13 | |
Rep 1
