2010 2011 BMW 5 Series Forum F10 BMW 535i 130 miles for 14 |
08-17-2023, 05:47 PM | #1 |
Rep 6
Is is this a good deal and would you recommend buying a 535 m sport with this mileage? I’m a owner of a 325i at 100k+ and have had no major issues. Still I’m not sure if a buying a BMW with 130k+ is a good idea because I hear they have reliability issues. The car looks in good condition
08-17-2023, 09:50 PM | #2 |
Rep 439
Drives: 2016 F10 BMW 535i M Sport
I got my 535i Financed through my bank for 19k around may-June with under 80k watch for oil leaks from OFHG, Valve Cover, Oil Pan, then watch the drive belt and pulley, then be sure to check service history for water pump and thermostat, those are normally the issues as far as I've read, keeping on top of Maintenance, and then plastic parts and piping and then hoses.
08-17-2023, 09:58 PM | #3 |
Rep 439
I don't think it would be unwise, however learn as much as you can about the platform. Read here for plenty of info before making that purchase. These are powerful and awesome machines.
08-17-2023, 10:02 PM | #4 |
Rep 3,054
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Price is great if maintenance mentioned above has been done. If it hasn't, budget at least another $3,000 or more for it. Plus tires. Plus suspension which is probably needing replacement. Plus trans flush (probably never done). But the base price is really good for a M sport '16, so having to do some maintenance shouldn't be a deal killer.
08-18-2023, 07:26 AM | #5 | |
Rep 6
08-18-2023, 07:32 AM | #6 | |
Rep 6
StradaRedlands5000.00 |
08-18-2023, 09:03 AM | #7 | |
Rep 6
08-18-2023, 03:44 PM | #8 | |
Rep 3,054
https://www.fcpeuro.com/products/bmw...rg-11519455978 Basically solid-state with three bolts to pop it on and off. Not the hardest job in the world, but not basic either. Plan on $1,000 for a shop to do it and the thermostat. Basically everything is a $1,000. You want X done: $1,000. You want Y: $1,000. Tires: $1,000. So the more the previous owner has done, the better! If you have good tires and the valve cover has been done, you're half way there! |
ChiltiCoatl891778.00 |
08-18-2023, 05:17 PM | #9 | |
Rep 6
Obviously want to check for leaks and if the water pump is functioning right and there’s no overheating |
08-18-2023, 09:22 PM | #10 |
Rep 439
If you try and replace water pump yourself, the job isn't that bad, a little tricky, it would be more of a relief if you replace it with the thermostat (always do them at once) (inspect hoses carefully and replace as necessary). The Engine Oil Pan would be more laborious in comparison. Would save you a lot of money and highly consider if you research and considering DIY. Plenty of websites and OEM parts to choose from.
08-18-2023, 11:29 PM | #11 | |
Rep 6
My main concern from the start was if there was any known issues this car was notorious for like certain expensive parts known to fail that I’m not aware of or something. I hear a lot about bmw’s and some of its lore and other times it may be true with certain models. I’m just relieved to hear that it’s stuff like this to watch out for. I’m also pleased to find out that this engine uses a timing chain and not a belt cause I was worried about timing belt replacement at this mileage I’m going to go see the car soon and do some checks on it and then make a decision but I’m really digging the car I just don’t want to be foolish or irresponsible about it. Hoping to strike actual gold and not fools gold Last edited by Thatoneguy57; 08-18-2023 at 11:34 PM.. |
ChiltiCoatl891778.00 StradaRedlands5000.00 |
08-20-2023, 12:33 AM | #12 |
Rep 439
Just remember, there are plenty of F10s to go around, and if it not be this one you will be touring soon, there will be others! If you decide to strike gold with this 5er! show it off !
08-21-2023, 09:09 AM | #13 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
Some things I would consider on any used more recent BMW. Where did it live? i.e. what climate was it in, rustbelt state, south? If it was in a hot climate BMW engine plastics degrade more quickly and could need some replacements. Did it have regular maintenance? If there is a backlog of repairs, the pervious owner was either not a car person or ran out of money to maintain it. Better to buy a car from someone who loved the car.
The engines and transmissions on BMWs seem very well made and will last well beyond 130K miles, if taken care of. I have a 2016 550i, with 96K miles and its ben very reliable. Only an oil leak here and there recently, and PCV replacement (diy job) due to plastic embrittlement. But I follow all the maintenance, trans, powersteering flushes, coolant changes, brake fluid etc. |
StradaRedlands5000.00 ChiltiCoatl891778.00 |
