2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum M5 exhaust cabin noise level
      07-06-2015, 11:37 PM   #1
AWF10
Drives: 2011 535i
I just got some m5 OEM exhaust installed on my 535i. I wired the exhaust flap open at all times. I'm happy with sound for most part but wanted to see if anyone else was having these issues. For the first 3 gears or so in regular driving mode it is too loud/drone exhaust note in the cabin. If I downshift a gear this helps with the sound while driving at all times. Is this issue due to the exhaust flap open at all times? Also does anyone know what this block metal that's attached to stock rear exhaust hangers? Thanks.
      07-08-2015, 09:59 PM   #2
TheEngineer
TheEngineer's Avatar
Drives: 2011 BMW 550i xDrive
Yeah, its right around the 1800 rpm mark. My wife is threatening to take my car back and install the stock mufflers back onto it.
      07-08-2015, 10:16 PM   #3
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
No way around that drone in Normal mode. Even my M Performance exhaust which is made for the 535 drones a bit in the range. Keep it in Sport and the issue is resolved.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      07-08-2015, 11:04 PM   #4
AWF10
Drives: 2011 535i
Yea it's a drone but loud only the first few gears especially at lower RPMs between 1000-1800k. And worse when speeding up with foot barely mashing gas pedal I get a sound that rumbles inside cabin so much and is too loud in the rear seats. Wonder if it would help decrease cabin noise level if I returned both valves to stock position and dynomat under rear seat and upper trunk lid portion inside of trunk.
      07-09-2015, 08:06 AM   #5
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
Thats what the flaps are for. Don't wire them open. You still get a very small drone but it's not overbearing at all.
      07-14-2015, 12:28 AM   #6
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
did you install the crossmember on the bottom? check out my post on my OEM M5 competition package exhaust on my 550i
BMW f10 550i Msport
      07-15-2015, 07:41 PM   #7
kondor
kondor's Avatar
13
Drives: F10 550i M Sport
Do you get any drone?
      07-15-2015, 10:39 PM   #8
spyroz
spyroz's Avatar
nope! Here's a link for my CP M5 exhaust.
BMW f10 550i Msport
      07-15-2015, 11:21 PM   #9
Mgone
Drives: X5
Sounds Good!!!
Did you install aftermarket dp also? I hear the turbo. 👌🏽👌🏽👌🏽
      07-16-2015, 12:56 AM   #10
spyroz
spyroz's Avatar
No, stock dp...but the Cp M5 exhaust is straight through..that's y probably.
BMW f10 550i Msport
      07-16-2015, 10:18 AM   #11
AWF10
Drives: 2011 535i
Yea I returned the exhaust flaps to the closed position and it's much better now while throttling.
      07-16-2015, 10:21 AM   #12
AWF10
Drives: 2011 535i
Yes I did install the crossmember bar between the 2 exhaust pipes before splitting off to each muffler. Only thing I can think is maybe that rear exhaust OEM hanger has something to do with it. I removed that piece off my stock 535i and used the stock m5 hangers which don't have that big metal block piece on it. The drone is much more tolerable now with exhaust valves closed position all times. Too bad 535i don't have the control to exhaust flaps.
      07-17-2015, 05:30 PM   #13
snowmuch
Drives: 2016 Macan Turbo
Just curious what the inline six sounds like with m5 exhaust?
      07-22-2015, 05:21 PM   #14
combatbmw
Drives: 20' X3M CP
http://www.exhaustmeister.com/
Get that!
Open it when you want it open, close it when you want it closed.
I planned to use mine, but my Meisterschaft system has its own valve system and remotes.
I can sell you mine for 100 shipped.
let me know.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 |
