2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: BMW Performance Black F10 Grille Install & Removing Bumper Silver Trim
      05-25-2011, 12:37 AM   #67
LACSTER
Drives: Hybrid
Originally Posted by mw5 View Post
Good write up Lacster
The part I don't get is how you pull the front bumper out. When I tried, I really couldn't get it to budge much. And how do you get your hand around to push the clips on the bottom? I have the M-sport bumper, but that shouldn't make a difference.
Make sure you remove all the screws under the hood.
That's all I ca think of if the bumper won't budge
      05-27-2011, 01:03 PM   #68
yohanlawrence
Sri Lanka
Drives: 2011 F10 532i
black grille
Hi the black grille looks cracking. Can you tell me where I can buy this from please. Agent here doesn't get them
      05-28-2011, 09:46 AM   #69
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
Look under the commercial marketplace section here of the forum. A few vendors here carry the grill. Now aftermarket matt grill available too.
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      06-20-2011, 02:01 PM   #70
px82
BMW E92 320D LCI MKIT | BLACK GRILLES | M3 SPOILER
px82's Avatar
Portugal
Drives: BMW E92 320D LCI M-Sport Kit
Thanks for this.
My dad just asked me to get some black grilles for his car. This info will be really helpful!
BMW E92 LCI M-KIT | PERFORMANCE GRILLE | M3 SPOILER | IPAD | CUSTOM SOUND IN THE WORKS
      06-20-2011, 03:05 PM   #71
Z4C_luvver
Z4C_luvver's Avatar
Drives: Phoenix Yellow Z4C
I went the other way
Well, sort of... I recently purchased a 550i chrome grille for my Sophisto Grey 520d. I thought the brighter grille actually looked better on the SG than the dark one.
Here's a few thoughts on the replacement process.
Firstly, thanks Lacster on your post. I don't think I would've attempted it without it.
Now, the removal. I'm an Auto Engineer, and this was not an easy thing to do. Reading Lacster's post and doing it myself had me thinking that BMW had tightened tolerances and fitment between then and now.
Firstly, a few pointers. When you undo the bolts and scrivets holding the bumper in place, don't expect it to open and fall forward like a gaping mouth at you. You have to prise it forward and you'll get about an inch or two opening (at best) to shine a torch down and get your screwdriver to.
Before you start the process of pulling the grilles out, I would (and did) put some lo-tack masking tape around the grille openings so you can reduce the risk of damaging the paint when you're pushing against the bumper fascia and when the grilles finally pop out.
I was really surprised at the force required to pull these out. I'd say, if your car was a recent build, don't expect an easy time of it. Once you do and learn from one side though, the other side seems a little easier. At least you know what to expect.
Of, course, it's all worth it though....
      06-20-2011, 05:16 PM   #72
px82
px82's Avatar
Portugal
Ok. Surely don't wanna ruin my father´s new car that has still not even arrived. It´s a 520d wagon.
It was a quite simple process on my e92 although I was a but scared of having to push the bumper a bit to much. Of course each car is different.
Thanks for the heads up.
      06-21-2011, 01:03 AM   #73
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
One of the members here managed to pop up the grills by squeezing his hand through the gap. No need to undo any of the bolts and screws. Have to have skinny hands though.
      06-21-2011, 02:55 AM   #74
Z4C_luvver
Z4C_luvver's Avatar
...and a good imagination.
I'd say that was nigh-on impossible. I'd like to see him do that on youtube!
Also, as I mentioned, they may have tightened the tolerance between the grille and bumper clipping points recently.
      06-22-2011, 11:11 AM   #75
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
believe or not. he only got red marks on his hands after. not an impossible task.
      06-22-2011, 01:08 PM   #76
LACSTER
Drives: Hybrid
he has girly hands
      06-23-2011, 06:49 AM   #77
niccomania
Drives: bmw f10 m sport
wowww excellent topic thnx for sharing!!!!
      07-19-2011, 05:03 PM   #78
FstopBMW
F-series Mastermind
FstopBMW's Avatar
Drives: 12' F30 M-sport
subtle but soo effective. Looks great!
"Success happens, but never by accident"
      08-03-2011, 09:10 PM   #79
Jay535i
Drives: 335i F30
Bottom mesh
I followed your pics they were great help I pulled off my little silver strips off my mesh sprayed them and the paint just came off after one day what's the best paint to use??? I used fusion.
      08-10-2011, 04:01 PM   #80
AWF10
Drives: 2011 535i
OEM performance grille and lower silver trims
The OEM black kidney grilles from the dealer are the same plastic grilles offered as stock...just painted from factory to match the shawdowline exterior trim as gloss black. You could probably get a shop to have your stock silver/chrome ones painted gloss black and it would be same product to save money! They just have clips holding them so all I did was use both hands and pull each grille directly out. I didnt take out the rubber seal or any screws. Didn't need to pry anything...just grab firmly and pull out! Took total of 10 mins to install both sides.
As for the lower silver trim pieces, I just flipped the tab in middle center out and applie pressure to remove it from the mesh grille. Didnt require to remove anything else in order to have these prepped and painted gloss black to match. Removing these took less than 2 mins each side.
      10-08-2011, 10:28 AM   #81
ianzammit
Drives: BMW 525D MSport
Purchasing these sports Grills
Can you please tell me where you can a set of these BMW F10 Black Grilles please.
Kind regards and many thanks for the pictures how to remove the grills.
      10-08-2011, 11:08 AM   #82
LACSTER
Drives: Hybrid
Contact www.ltbmw.com and send them en email with your shipping address and they'll get you a set asap!
      10-08-2011, 11:31 AM   #83
inny
Cyprus
Drives: F10
2011 BMW F10  [0.00]
1995 BMW E34  [0.00]
2007 BMW E60  [0.00]
Can someone please take a few pics (close up) on the points I circled in the attachment?
Seems that i might have pushed it a bit more and im not sure about the gap between the hood the bumper.
      10-09-2011, 02:46 AM   #84
ianzammit
can someone please tell me where I can get the black grills for the BMW F10??
      10-09-2011, 11:54 AM   #85
LACSTER
Drives: Hybrid
look up a few post I already answered your question.
      10-09-2011, 07:59 PM   #86
2011535i
Drives: 2011 535i, CbnBlk, M-Spt, 6-MT
Installed my grills today. It helps to have a slender hand. My daughter was happy to help. Now my Carbon Black M-Sport looks menacing! Thank you Lacster for the instructions and pictures.
      10-09-2011, 08:27 PM   #87
LACSTER
Drives: Hybrid
You welcome sir
      10-17-2011, 07:31 AM   #88
Douggie
Drives: BMW X1, X3
How about the trim on the window frames? I personally think it would look much better if all chrome trims are all blackened to match the grilles. Just my taste.
