06-02-2015, 11:59 PM | #23 |
Rep 3,241
Much of it is my lab environment. I'm only as good as what I know with my job. So I'm constantly playing with new technology. I have a virtualized environment with a bunch of virtual servers doing various applications. There's other stuff I do with my environment that'll blow your mind. Such as I'm away from home right now for work. I'm in my hotel room connected into one of my home's WiFi SSIDs through the hotel's guest WiFi system. Let that sink in for a moment on what is happening and what I'm doing.
06-10-2015, 12:08 AM | #26 |
Rep 11,135
06-13-2015, 12:38 PM | #27 |
Rep 5,538
I also need recommendations. I am looking for something decent: 1 for home (must have motion sensor and wifi) and 1 for balcony (must have maybe 50 meters range on IR and wifi) to monitor my car on the parking lot from 4th floor. I dont need super clean images, just want to see if and who enters my condo and touches my car. I want to record 3 weeks to my full-time running PC or have builtin storage option, as well as alerts and live view via Android phone. So i dont need 1080p or even 720p maybe....
06-13-2015, 01:18 PM | #28 |
Rep 435
What do you guys suggest for a decent 2 outdoor front and backyard and 1 indoor camera for when I'm traveling overseas I can check to see what is happening at home anytime throughout the day? Basically what previous poster above me said..
06-14-2015, 08:56 AM | #29 | |
Rep 11,135
I think the IR range is 30 meters, but it does have Wifi. All cameras these days will be 1080p or more. As far as recording is concerned, it'll record as much as you have available in hard drive space. You can use the software it comes with, or buy something like Blue Iris, XProtect, Sighthound, Exacq, etc. The Hikvision app is actually very slick for the iPhone, have not tried the Android version. The cameras will have dual streams, and the highest resolution one will be used for recording/PC. The secondary stream is what you'll get on your mobile devices. |
06-14-2015, 08:58 AM | #30 |
Rep 11,135
I would recommend the HIkvision DS-2CD2132F-IS dome or the Hikvision DS-2CD2032 bullet cameras for outside use. Then use the one I recommend above for inside use. Since it's Wifi, you can place it all over the house pretty easily. The other two will be permanently mounted.
06-14-2015, 01:21 PM | #31 | |
Rep 5,538
06-14-2015, 02:14 PM | #32 | |
Rep 5,538
Just remembered that I have account at local ADI store, will check prices with them too. My total came out to $235 at "CCTV Camera China"... DS-2CD2432F-IW + DS-2CD2132F-IWS + DS-1258ZJ wall-mount, I assume need 2 12v power supplies from Home Depot as well |
06-14-2015, 02:55 PM | #33 |
Rep 2,404
I am using foscams, the older models were pretty horrible, but the newer models are really good. Using tiny cam pro on android phone and watch to view them. And using IP camera viewer on the PC.
06-14-2015, 04:22 PM | #34 | |
Rep 11,135
You don't need the power supplies as you'll likely use a PoE switch, which will power the cameras. |
06-14-2015, 11:33 PM | #35 |
Rep 3,241
I wouldn't use the DS-2CD2432F-IW in an outdoor situation even if the camera is going to be protected from rain. This camera has vents which the creepy crawly type critters can enter into the camera. I have one of these cameras in my garage but for the most part there shouldn't be any bugs crawling into it. You really need a IP66 (fully sealed and weather proof) camera for outdoor use.
06-14-2015, 11:48 PM | #36 | |
Rep 3,241
I would also use an AC adapter to test the IP cameras especially the outdoor ones before going through the trouble of testing them outdoors. An alternative is to use an inline PoE injector. A PoE injector is just a box that is inserted between an Ethernet jack or switch and the IP camera. The PoE injector is then plugged into a wall power outlet. |
06-15-2015, 11:53 AM | #38 |
Rep 11,135
06-15-2015, 11:55 AM | #39 |
Rep 5,538
06-15-2015, 12:01 PM | #40 |
Rep 11,135
06-15-2015, 12:20 PM | #41 |
Rep 5,538
06-15-2015, 12:28 PM | #42 | |
Rep 11,135
At this price, they are disposable. |
06-15-2015, 03:08 PM | #44 | |
Rep 5,538
Their price is still good, about $50 more for each camera. I could probably get them down even more closer to Amazon pricing but didnt want to argue |
