05-06-2022, 01:25 PM | #1 |
Rep 1,254
Oil consumption
Hello
Current owner of 2013 BMW 550i with 67,910 Last year I started recording my oil consumption. I changed oil @ 60,000 miles Since I put almost 8,000 miles to be exact 7,910 I been averaging 1,200 miles before I have to add 1qt of oil. I added exactly 6qt of oil during this period of time. Today I was adding air to my rear tires I noticed lite smoke coming out of my tail pipes temperature outside 65° and sunny. I finished with air I sat in my car for roughly 5 minutes letting car idle I opened door ad step on gas paddle pretty hard couple of time Well I ended up with cloud of smoke coming out of tail pipes. I immediately called dealer to get this sorted out service advisor told me he will find out to tell me what my options are. From what I have read online since my car is at 67,910 miles out of pocket I have to pay 15%. Curious to hear if any of you had to go through this process and how much did it ended up costing you, what should I look out for. Thanks in advance
05-06-2022, 01:57 PM | #2 |
Rep 7
Sounds like the turbo.
StradaRedlands5009.00 |
05-07-2022, 10:49 AM | #3 |
Rep 172
I have 2013 550 with 68k. I had the same issue but was adding 1 qtr every 2500 miles. My valve seals were replaced back in 2021 under the class action. I paid zero. Since then, I didn't have to add any oil between oil change. Good luck..
EL Jeffe 5612.50 |
05-07-2022, 11:15 AM | #4 | |
Rep 1,254
Because lawsuit states Up to 70k miles you must pay 15% Thanks
05-07-2022, 05:25 PM | #5 |
Rep 172
Yes, for 60k to 70k, replace engine is subject to 15%. However, my dealer did the oil test and decided to go with the valve seal replacement in stead of engine replacement. Free of charge. Both have 2 years warranty. You might want to ask around as your mileage is pretty low.
StradaRedlands5009.00 EL Jeffe 5612.50 |
05-13-2022, 08:40 AM | #7 | |
Rep 1,254
It's Friday I haven't heard back nothing Only thing I got was from tech recorded video stating hello this is so and so I'm inspecting your car for oil consumption. Service advisor told me Monday they don't like doing seals they typically drop new engine. I wouldn't mind new engine
05-13-2022, 08:42 AM | #8 | |
Rep 1,254
05-13-2022, 10:18 PM | #9 |
Rep 1,254
Update
So I bought my car when car had 13k miles I was told today by dealer engine does not match car vin number so they can't do nothing about it until we figure out who changed engine I don't know wtf to do now
05-14-2022, 10:51 AM | #10 |
Rep 172
😳😲 that sucks..
EL Jeffe 5612.50 |
05-18-2022, 09:22 AM | #11 | |
Rep 247
Also - warranty is one thing, but the language in the lawsuit is very clear and simple and I do not believe there are any exclusions for prior engine replacement. It might impact the mileage calculation, but shouldn't alter BMW's obligations under the settlement. |
05-18-2022, 02:33 PM | #12 | ||
Rep 1,254
05-18-2022, 03:34 PM | #13 | |
Rep 1,254
12-17-2022, 10:54 AM | #14 |
Rep 1,254
update as of now car have all 32 valve seals replaced and no more smoke its running like champ.
I did valve seals in my garage it took me about 7 days and $1200 dollars with rental of master set AGA valve seals tools.
12-17-2022, 11:01 AM | #15 |
Rep 1,254
Here are some photos
StradaRedlands5009.00 SWFLf10373.50 |
12-17-2022, 11:07 AM | #16 |
Rep 1,254
I forgot to give a credit to SWFLf10 for hooking me up with ista+ this job would be impossible without ista+ thank you SWFLf10👍🏻
12-18-2022, 07:55 AM | #17 |
Rep 639
EL Jeffe 5612.50 StradaRedlands5009.00 |
