2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 550i Motor mounts ?
      11-15-2016, 08:49 AM   #1
550Reasons
550Reasons's Avatar
Drives: F10 550i
Hey guys took the 550i to do some maintenance and downpipes install. Found out my oil pan was leaking so thats getting fixed, but while in there they noticed that one of my motor mounts was shredded up, part is like 130$.
Im just curious if anyone has had it happen to them ? or even notice anything different.
I never noticed much difference except some quick rough idles but figured that was just the shitty injectors lol, but hopefully this will make my car feel a bit less jerky or smoother ? lets hope so !
2011 550i
2013 M5
2014 M5 CP
2016 550i
      11-15-2016, 01:22 PM   #2
MattPro
MattPro's Avatar
Drives: '13 F10 550iX, '91 E30
Motor mounts should help smoothen it out a bit. The mount is just basically a big rubber bushing that absorbs vibration and flex from the torque of the engine. Depending on how bad it is, it can allow almost all of that vibration to travel through the mounting bolt/stud and you'd feel it. If it's bad enough the engine mount arm could be resting on something it isn't intended to as well.
Thanks,
Matt
2013 F10 550iX Carbon Black/MSport
BMW Fault Code DB
      11-15-2016, 02:17 PM   #3
550Reasons
550Reasons's Avatar
Drives: F10 550i
What about you since your putting way more power have you checked your mounts ?
2011 550i
2013 M5
2014 M5 CP
2016 550i
      11-17-2016, 06:33 PM   #4
MattPro
MattPro's Avatar
I haven't, but now that you mention it I have a bit of shake at idle. When I do my shocks next weekend I'll check them out.
Thanks,
Matt
BMW Fault Code DB
