2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK 2010 bmw 525d f10 headlight vertical aim fault
      01-07-2017, 01:46 PM   #1
balfron100
Drives: Austin 1100
Angry 2010 bmw 525d f10 headlight vertical aim fault
Hi, Can you help.
How do I remove and refit the headlight from a 2010 F10 525d.
My car is showing the following fault, " headlight vertical aim fault", the angle halo has also stopped working.
Any advise on this, I think its a fault with the control module as the headlight and full beam work, can't find a replacement module anywhere.
      01-13-2017, 03:02 AM   #2
suj999
Drives: F06 640d M Sport, F10 520d SE
Control module. Buy 2nd hand headlight and remove module from there
      05-17-2018, 09:12 AM   #3
xyz213
Drives: bmw f10
I would highly recommend an ebay user who specialises in this issue. He is able to resolve the problem and has lots of happy customers. It would save you a hell of a lot of money than going to stealers. Here is the link below:
Check it out and thank me later
https://www.ebay.co.uk/itm/253551087...280&rmvSB=true
JLR19691882.00
      05-21-2018, 05:33 PM   #4
Huskyman
Drives: BMW F31 340i
To remove the headlight
Front bumper off, and then remove the trim piece on the side of the engine bay the headlight you want to remove(alongside the wing) and then unbolt the headlight. Pull it forward and release the connector. HTH.
Or look here ;-)
https://www.newtis.info/tisv2/a/en/f...ght/1VnXkwBJGi
