2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Code 2TB on a 205 F10
      01-16-2015, 01:23 AM   #1
megabmw
megabmw's Avatar
52
Drives: GT 630dx and i3
I have experience with both both the Sport auto and normal auto in the F10, and the Sport auto is my choice no 1
Just got a 2013 F10 530d x-drive with 205 and I want to try the 2TB coding on it. I do not care about the nice short sport auto shifter and the paddles, I do not want to retrofit them.
Just want the software which gets me faster shifting times.
Any one done this? What what ecu's need coding after I change VO.
Is it as simple as that? Or will the gearbox need new software?
      01-19-2015, 10:15 AM   #2
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
FA (VO) Replace 205 with 2TB.
Code new FA in ECUs EGS, and GWS.
Simple as that, and no new software for the gearbox, but I never noticed faster shifting times...this did change the display mode to be S1, S2, S3, etc.
File Type: pdf FA (VO) Step-By-Step (MWPos) 8-24-2013.pdf (1.05 MB, 8614 views)
Regards,
MWPos
      04-29-2016, 04:22 AM   #3
quicksilv86
Drives: BMW F11 530d 2012 Pre LCI
Could you please confirm we also need to code new FA in ECU
- KOMBI in order to show Sport + in the cluster ?
- CID in order to show animation in CIC?
Thank you in advance
      04-29-2016, 11:35 AM   #4
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
I think that this is not related to the gear shifter functionality. The rocker switch on the center console is what causes Eco/Comfort/Sport/Sport + modes to be selected and displayed in the Cluster. The change with this coding is that the gear indicator will show S1, S2, etc. instead of the simple S or D that we normally see.
Is this what you are looking for?
Enable Sports Display menu when switching to sport driving mode
HU_CIC=>KOMBI=>SPA_SPORT_ENABLE=>aktiv
Again, this is requires that rocker switch which changes the driving mode.
Regards,
MWPos
      04-29-2016, 04:25 PM   #5
quicksilv86
I'm sorry but i don't understand...
For me, add 2TB and code ECUs should allow, in particular, to see "Sport+"
-in the cluster like the 2 photos i attach
-in the CIC screen like the photo i attach.
So, could you please confirm (or not) coding only GWS and EGS ecus is enough to see this ???
Thank you in advance,
      05-01-2016, 04:48 PM   #6
MWPos
MWPos's Avatar
Drives: 2013 535i
2013 535i  [0.00]
I believe that the rocker switch in the attached picture is the only way you will be able to change between Eco/Comfort/Sport/Sport + and to see the status in your Cluster and iDrive.
The gear shift indicator is what you will see differently in your Cluster (S1, S2, S3, etc...).
Regards,
MWPos
      05-02-2016, 04:28 PM   #7
quicksilv86
Thank you for answer.
I think i'm not clear.
I dont have sport+ in my car: only 3 status eco/comfort/sport i can change indeed with the rocker switch.
My aim is to add this sport+ status in the cluster and idrive.
And i thought adding 2tb could be the solution...
That's why i asked you previously if i needed to code Kombi...thinking without coding this ecu, the status sport+ in cluster and idrive would not appear....
      05-02-2016, 08:59 PM   #8
Yes.... Change 205 to 2TB and you will get Sport+. There is other coding (IIRC) necessary to get S1-XXX in the display.
      05-03-2016, 11:10 AM   #9
quicksilv86
Once i get the enet cable, i'm going to add 2TB in accordance with the pdf document named "FA (VO) Step-By-Step (MWPos) 8-24-2013.pdf ".
I will code new FA in ECUs EGS and GWS only and i will see if "sport+" appears in the cluster and Idrive as in the pictures i attached previously.
      05-03-2016, 01:38 PM   #10
Sunny 528i
Drives: 2012 528i
So by adding this "sport+" to non-sport+ vehicles, will you see any difference at all in driving? I have the eco/comfort/sport only. I would definitely try this if there is any gain from adding it.
      05-03-2016, 03:32 PM   #11
Not really.... Sport+ just automatically disables part of the traction control. I think it enables DSC.
      05-04-2016, 01:32 PM   #12
Sunny 528i
Drives: 2012 528i
Let us know if this works! I'm waiting for you to verify before I continue to do this myself. Thanks
      05-04-2016, 02:18 PM   #13
I've done it, it works just fine.
      05-12-2016, 03:20 PM   #14
quicksilv86
As i thought, coding new FA in ECU EGS and GSW is not enough....to get Sport+ displayed on the cluster and on my CIC screen.
I'm going to code new FA in Kombi and ICM too as i have seen on others posts.
      05-12-2016, 06:04 PM   #15
quicksilv86
It works!
You have to code new FA (as explains the pdf file attached above) in 4 ECUs :
-EGS,
-GWS,
-Kombi,
-ICM.
      05-18-2016, 08:12 PM   #16
Sunny 528i
Drives: 2012 528i
It works!
-EGS,
-GWS,
-Kombi,
-ICM.
Nice! I'll be performing this myself based on your instructions! Notice anything different when in sport+? have any pics?
      05-21-2016, 07:34 AM   #17
quicksilv86
The pics are exactly the same i attached previously.
The sport transmission is really good : 7 speeds in sport mode vs 8 in DS mode...It seems more brutal and i like that !
      05-28-2016, 06:36 AM   #18
Indigo
Indigo's Avatar
Drives: 2012 F10 520D
I coded 2TB on my 520D without paddles shift steering wheel. all working just fine but showing error paddleshift connection is open or something like that.
How can I remove this? or 2TB got to be with paddle shift steering wheel?
      06-10-2016, 01:00 AM   #19
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
FDL-code the following after VO-Codiing:
SZL_LWS_03 > Variantencodierung 3000 > Lenkrad_Schaltpaddles = nicht_aktiv
      06-15-2016, 06:07 AM   #20
Indigo
Indigo's Avatar
thanks, in my case turn out its Variantencodierung_2_2_1
      06-15-2016, 09:58 AM   #21
snj1013
Drives: 2011 528i
+1
      06-30-2016, 12:32 PM   #22
Sunny 528i
Drives: 2012 528i
Just did this on my 2012 528i following quicksilv86 method and it worked!!
