2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 19x11 +12 offset
      05-17-2014, 08:15 AM   #1
Nhan
nhanweezy
21
Drives: 2011 z4is
19x11 +12 offset
http://www.m3post.com/forums/showthread.php?t=980484
Will this work on the rear? What tires will I need to fit our F10s?
      05-17-2014, 08:28 AM   #2
Dan1416
Dan1416's Avatar
39
Drives: 2013 528 x-drive
Won't work. You'll have over 30mm of poke. Even with stretched tires it wouldn't be close
      05-19-2014, 11:20 AM   #3
Nhan
nhanweezy
21
Drives: 2011 z4is
Any other inputs..???
What about these bbs lm
http://www.m3post.com/forums/showthread.php?t=973153
      05-19-2014, 12:00 PM   #4
LACSTER
Drives: Hybrid
M3 offsets won't work on our F10's
      05-20-2014, 03:42 PM   #5
VMRWheels
VMRWheels's Avatar
2040
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Definitely will not work on the F10.
      05-24-2014, 11:44 PM   #6
ahmad_1290
ahmad_1290's Avatar
Drives: 2011 535i
Here's a 19x11 +26. 295/30.
      05-25-2014, 05:04 AM   #7
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Is that your F10?
      05-25-2014, 11:03 AM   #8
ahmad_1290
ahmad_1290's Avatar
Drives: 2011 535i
Originally Posted by remmib View Post
Is that your F10?
Yeah, Just test fitting my brothers wheels he had laying around
      05-26-2014, 04:36 AM   #9
remmib
remmib's Avatar
Norway
1568
Did you test drive it too?
      05-26-2014, 08:33 AM   #10
ahmad_1290
ahmad_1290's Avatar
Drives: 2011 535i
Unfortunately I did not, but It would have cleared fine
      05-26-2014, 02:18 PM   #11
STOOF
Sunburned
STOOF's Avatar
Drives: '16 F83 M4 Convertible 6MT
2013 BMW 535i  [0.00]
no way they would clear
i have 20x10.5 +27 and when i had 285s they destroyed my fenders
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired
2011 Z4 SDrive35i 6MT- Retired
      05-26-2014, 05:05 PM   #12
ahmad_1290
ahmad_1290's Avatar
Drives: 2011 535i
Well obviously, We're talking about 19 inch. It also depends on your ride height.
      05-27-2014, 02:00 AM   #13
guess2098
Drives: 2022 Taycan GTS, 2018 M4, 2016
if you want to go for x11, offset needs to be 34mm
according to many wheels for sale F10 members
20x10.5 +40mm is good
according to Forgestar
20x10.5 +35mm for most you can go out
calculate 20x10.5 +40mm to 20x11 +34mm
Inner Clearance = same
Outer Position = EXTEND an extra 12mm
calculate 20x10.5 +40mm to 20x10.5 +27mm
Inner Clearance = 13mm MORE
Outer Position = EXTEND an extra 13mm
      05-27-2014, 04:39 AM   #14
remmib
remmib's Avatar
Norway
1568
I guess you mean the outer position should with 11" should be the same as with 10.5".
BTW, my 20x11 are ET46.
      05-27-2014, 04:15 PM   #15
guess2098
Thank you for your info
i don't have enough data to know how inside we can go for, the most inside offset i see is 10.5 +40. that is why i did not change the inner clearance but increase outer position.
if your 11 +46 does not have problem on rear, than it is the best offset for 11" that is for sure and i can use your data to calculate.
also could you share your front offset please. right now the data i have is only from +25 to +28 for 9"
thanks
      05-27-2014, 06:06 PM   #16
remmib
remmib's Avatar
Norway
1568
thanks
There's lots of room in the rear of the f10. I can still get a finger between the inside of the rear wheel and the suspension.
My front offset is ET26.
      05-28-2014, 06:46 PM   #17
guess2098
thanks for your help man
