2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BSW Speaker Upgrade
      09-19-2014, 01:23 PM   #45
pdrf10
A Man of Wisdumb...
pdrf10's Avatar
Drives: 2011 F10 550i M Sport
Originally Posted by fung0001 View Post
no video could be found for the deadening installation
I think if you go to BAVSOUND's YouTube channel and search their posts on installations for vehicles other than the F10 chassis, you'll get the basic idea on how/where to apply the deadening insulation.
Also, I would recommend you send them an email, as they're usually very good about responding promptly with assistance...
Good luck with your install!
      10-10-2014, 05:17 PM   #46
BawstinMike
Ma' the meatloaf....
BawstinMike's Avatar
Drives: 17 BMW F15 MSport
I am still holding out, I must have missed that sale because its showing 1299 still now for the Stage 1. 3 Years in development for the sub seems a bit extreme to me. My main concern is the existing OEM HK subs will clearly be outmatched. And just exacerbate the low end situation. However, I have been told some of the low end is made up with the new speakers.
I too have sent an email over to BSW about the subs. Awaiting their response. If I were to do to an upgrade I might as well do it all in one go.
[SIZE="2"][FONT="Trebuchet MS"][SIZE="1"][SIZE="2"]Current Ride:
2017 X5 MSport
(RETIRED) 2014 535i M Sport
      10-11-2014, 12:04 PM   #47
cas175151
Drives: F10
BAV Sound
You did miss the sale. It was happening about 2-3weeks ago. I got them for about $500 on sale with a coupon they sent me for 10% off. Awesome speakers and very simple install. Unbelievable sound. Can't believe the difference. Anyone that has listened to them cannot believe how great it sounds. Definitely works well with the woofer. Keep watching the site for the next sale
      10-12-2014, 08:55 AM   #48
fung0001
Drives: f10 2013 520i Hartge Tuning
Installed (not by myself) and the sound is good!
For the basic 6- speaker system in Hong Kong
recommend to install by shop as there is no fitting clips on the deck for holding the rear tweeters ( & I am sure that you cannot do it yourself without the necesary parts)
      10-12-2014, 09:12 AM   #49
493263
493263's Avatar
71
Drives: 2011 550i xDrive
BawstinMike,
The stock subs have always sucked if you're a bass fanatic. For most people, I would say it's fine. It's not enough for me but it's adequate for now.
      10-15-2014, 03:00 AM   #50
fung0001
deadening installed on the same date
noise from front passanger door which can't be fixed by BMW HK disappeared
Y(^_^)Y
      10-23-2014, 08:52 PM   #51
pdrf10
A Man of Wisdumb...
pdrf10's Avatar
Big Sale @ BAVSOUND!
Greetings all -
I just received an email from the good old boys at BAVSOUND, and they've got a big sale going on for the F10 Stage One kits. Up to $500 off depending on your sound system configuration, and the promotion is good for the next 30 days!
It's time to strike if you've been on the fence waiting for a price drop.
FYI...
      10-25-2014, 06:26 AM   #52
fung0001
Thks
Will recommend to folks in hk
      10-27-2014, 02:05 PM   #53
Sohl
Drives: BMW F11 -2013
i almost pulled the trigger on the stage 1, but 220 dollar in shipping cost to sweden was to much for me
      10-27-2014, 09:42 PM   #54
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Went to several shops and it looks like most shops won't touch the car for many different reasons. Also, they said since the stock speakers are 2ohm there's not a whole lot of speaker choices unless you run an aftermarket amp which then maybe a problem using the factory head unit. Might opt for the BAV but anyone know if the sub under the seat can be replaced with a better sub or are we just out of luck? I know there are shallow mount subs out there but which one would be compatible?
I did find a 5 page thread on another site regarding adding subs but just seemed like too much work for a shop to do and of course price would be expensive. Without the ski hole in the backseat they ran into the trunk being a complete enclosure in itself. Not so sure about hacking my backseat to let the air through the trunk into the cabin? Anyways if I can at least find a replacement sub under the seat with the BAV I might be just satisfied with that...maybe lol!
      10-28-2014, 12:11 AM   #55
fung0001
I have exactly the same concern earlier
Trust me
It worth for this cost
      10-28-2014, 12:17 AM   #56
fung0001
Even my wife (who finds any kinds of music a " noise" ) has the follow comment:
You spent hk$5xxx and of course the sound is better
      11-03-2014, 06:37 PM   #57
fung0001
i note that bvs has added an option of basic sys stero
& the result is that this product does not support your sys
l would like to add that the basic sys in hk and uk does not support center speakers
other speakers work well & folks can just select the speakers fitting your car
      11-05-2014, 11:21 PM   #58
TJBentley
TJBentley's Avatar
Drives: '12 528xdrive
Any opinions on pairing a jl audio xd600/6 to the BSW stage 1 Hifi speak system?? BSW does not list specs so it is difficult to match up. It would be about 75watts rms x 6
      11-05-2014, 11:24 PM   #59
TJBentley
TJBentley's Avatar
Forgot to add, I am ultimately trying to achieve higher volume while improving sound quality also. Will be adding subs in the trunk and don't want the highs to drown out.
      11-17-2014, 06:04 PM   #60
tam425
Drives: 2013 F10 M Sport
Hi fung, i am from Hong King as well with F10, can u tell me where can i get bacsound installed? Wanna to order to catch the big discount now! My car comes with basic 6 speakers system. Many thanks
      11-17-2014, 11:47 PM   #61
fung0001
Kindly search Carrus Workshop for its contact no.
It is in North Point & asked for $800 including installation of sound proofing material ordered from Bav
      11-17-2014, 11:51 PM   #62
fung0001
Further
You can ask buyyippee to recieve the good ordered from Bav in US & transport it to HK
It can save enough money for installation
      11-18-2014, 12:00 AM   #63
tam425
Further
Thank you so much! U mentioned that u cannot install them by yourself. Which procedure was difficult? Thx
      11-18-2014, 04:29 AM   #64
fung0001
No fitting clip to hold the tweeters at the rear for the basic model in hk
Removing the door panel is not that easy, you will regret if any tiny parts were not re-installed properly.
      11-18-2014, 08:19 AM   #65
tam425
Thanks a lot! Happy driving!
      11-19-2014, 12:07 PM   #66
BananaCar
Drives: N/A
Current BAVSOUND is on sale for $799 before coupon. I am tempted but might wait for Christmas or BlackFriday?? I have HK sound so I'm not in too much of a rush. However if they introduce a sub-woofer. I would get the kit.
