2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 550i - M5 Exhaust Question
      03-27-2015, 05:36 PM   #1
GWP
Drives: 2011 550i
I currently own a 2011 550i w/6 speed manual trans. As you may already know, exhaust system choices for this car is very slim. My question is will a 2013 M5 exhaust system work on my car. I do know that the piping is larger on the M5 and would require additional work to adapt from the 550i's smaller diameter to the M5's larger diameter piping at the down pipes. I have found several companies that manufacture complete systems for the 2013+ M5, so I am considering ordering one of those systems and modifying it to adapt to my 550i. Of course I know that the rear diffuser will need to be replaced with an M5 diffuser. Has anyone done this or can confirm that everything should line up?
Thanks in advance!
      03-27-2015, 11:33 PM   #2
ARC550
Drives: M3, X5, 720s, X5, 750xi
Thanks in advance!
Yes will fit!
      03-29-2015, 10:24 AM   #3
GWP
Drives: 2011 550i
Originally Posted by ARC550 View Post
Yes will fit!
thanks for the reply!
      03-29-2015, 03:30 PM   #4
Mbbrewer
Mbbrewer's Avatar
150
Drives: 550i
Dude tons of people of M5 exhaust including myself. It fits
      04-01-2015, 11:53 PM   #5
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 07-335/12-328/18-M4/21-M4CP
As mentioned above it fits.
It would also be a good idea to check out the AA 550i exhaust.
https://x-ph.com/sale/
Phone number 702-494-9435
      04-02-2015, 07:28 AM   #6
DesiRacing-AjayB
Drives: BMW 550i xdrive f10
I just did the swap. it fits, took the guys at the exhaust shop about 2 hours to do it.
      04-08-2015, 04:21 PM   #7
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
I'm about to install my M5 Competition exhaust on 550i, a crossmember is highly recommended to eliminate drone. Just wondering how much did it cost you for the labor DesiRacing?
BMW f10 550i Msport
      04-08-2015, 04:35 PM   #8
DesiRacing-AjayB
It cost me 235
      04-08-2015, 06:31 PM   #9
dan the man
Drives: 2017 M4 CP
M5 exhaust pipe is 3in and you can slip on the 2 3/4in OEM 550 pipe. You don't need to change the diffuser unless you like it and have the bucks. If u really need more sound you can go ahead for muffler delete and wake up all your neighbors.
Thanks in advance!
2017 F82 M4 CP - Black Sapphire Metallic - drive it like you stole it
2014 F10 550xi M Sport - Jet Black - gone
2010 E92 335i Coupe - Black Sapphire Metallic - gone
2004 E46 330xi Sedan - Black Sapphire Metallic - gone
      10-28-2016, 02:54 AM   #10
Jabreezy
Jabreezy's Avatar
Drives: 2011 BMW 550I
it works! and sounds amazing
